Reversing front spindles to clear oil pan - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2011, 06:07 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
this is my son's first car, it's a '75 Granada he got for free, pretty decent interior and fresh paint, didn't come with engine and steering box.
He's already overhauled this Ford 300 CID Inline six from a Ford truck that I got in the shop, it's free so it's going in the car mated to a fresh C4 tranny.
there are two main issues, first and simplest is that the engine is longer than the "small" 250 sixes that ford puts in the granadas so no room for a mechanical fan up front, an electric unit in front of the radiator solves that easily, the real problem is down there, the oil pan has a huge REAR sump, the granada has no room for a rear sump.
two ideas came to my mind, one would be fabricating a conversion to move the sump to the front, not easy but feasible, second and this is the subject of this post, what if I reverse the spindles, I mean installing the left on the right and viceversa, so the steering arms face the front instead of the rear, this way I would be able to install a front rack and pinion that would make life pretty simple.
Would the KPI and Caster remain the same? or would get backwards?
Having the calipers on the front side I think would make no difference, just longer hoses, several euro cars are this way.
Same thing I'm thinking of doing to this customer's '63 Nova that I'm working on and will get a 350 SBC, the correct sump can be bougth but I think the front rack and pinion would be a better option.
Please tell me your toughts.
Augusto.
Old 09-16-2011, 07:00 PM
KPI and caster will not be changed.
But what WILL be changed is the Ackerman angle.
As the front wheels steer, the inside wheel steers to a greater angle than the outside wheel, so the front tires do not have to scrub sideways. This is done by angling the steering arms inwards at the back.
If you swap the spindles over from side to side, the whole thing then works backwards. The outside wheel steers a greater angle than the inside wheel. Expect massive front tire wear, and steering that does not feel right.
Old 09-16-2011, 08:30 PM
Wiki Edits: 27
4 X4 Pan ?
Have you looked at the oil pan from a 4 wheel drive truck or ford van. //some of them are different to clear the front axle. It might work for you.
Old 09-16-2011, 09:56 PM
Augusto's Avatar
hmm, didn't think of the ackerman, I'm familiar with it 'cos it's very common to mess with it on kart racing that I do often, I'll make a cad drawing of the whole setup to simulate it and see how it will behave, seems like it would be a better idea modifying the oil pan, maybe I could get across one off a 4x4 truck as timothale suggests.
the rack and pinion seems easy to do in the stock location, just found that summit has a kit to do it on Novas, will work fine on the granada.
Old 09-17-2011, 06:04 AM
Last journal entry: A few ongoing projects
Personally I would look at different pans for the 300. They were used in a lot of different applications including cars trucks and vans and as mentioned you might find one thsat fits with little or no modifications. Even if you have to build or have built a custom pad I believe you will be a lot of time and money ahead doing that over re-inventing the steering.
front spindles shack Suspension - Brakes - Steering 1 04-03-2011 06:28 PM
el camino/ s10 front spindles arizray Suspension - Brakes - Steering 4 02-06-2011 07:45 AM
Spindles front, differential rear Blanceman Suspension - Brakes - Steering 2 06-19-2009 06:07 PM
Can I weld a tab on my front spindles? Quarter Flash Hotrodders' Lounge 15 10-09-2006 02:25 PM
reversing spindles cboy Suspension - Brakes - Steering 4 10-27-2004 12:36 PM
