revving an engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2005, 09:23 AM
New Member
revving an engine
when is it bad to rev an engine? like while driving and then shifting into neutral? tnx
Old 01-13-2005, 09:32 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
revving an engine
Each engine will have its own max rpm. Popping a car into neutral at high rpm is never a good thing. Missing a shift is pretty well the same thing. If it didn't develop a knock it should be ok.
Revving a cold engine to warm it up is bad. Making sure your choke is set properly will save you alot of grief and money.
Installing a rev limiter is very good insurance. Installing a shift light will keep you consistent. The stronger the parts the higher it can rev without grenading. The stronger the parts the more expensive the motor. Money is a large factor in dictating your rpm limit.
Racing is all about revving the motor to the brink of disaster. Don't rev enough you lose. Rev too much, you grenade, you lose.
Old 01-13-2005, 09:33 AM
Frisco's Avatar
Glad To Be Here
It's not bad to rev an engine! It won't even move the vehicle much unless you do!
It can be bad to OVER REV an engine whether in neutral or in gear.
Old 01-13-2005, 09:46 AM
bracketeer's Avatar
489 Lemans
funny
Thats pretty funny frisco. Made me laugh before breakfast.
