rewiring a 88 caprice classic - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2009, 03:34 PM
Ok so my question: Is it any company that sells complete re-wiring kits for chevys?? I have a 88 caprice that I'm rebuilding. Took the 305 out and put in a 496. Me bien a first time builder did not label any of the wries when I took the car apart so instead of figuring it out I think it's best to just buy a new wiring kit. I need all the basics, lights, brakes, wipers, etc..Just need. Help wit who I should look into
Old 09-02-2009, 03:45 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Sorting out the original wiring would be my choice, but Painless has wiring kits.
Usually, these kits used in scratch-built cars or for changing from TBI to carb, etc., but I see no reason (other than cost) that you couldn't adapt something from them to work in your box.
Old 09-02-2009, 04:05 PM
ericnova72's Avatar
More for Less Racer
It can't be that hard to find a factory wiring schematic with the color codes on it and just trace things out. A lot easier than a whole new harness IMO, especially if you are keeping things like power windows, locks, delay wipers, etc.
Old 09-02-2009, 09:15 PM
Wow, you want to spend $350 for a wiring kit instead of $35 for a factory manual?
I'll give you my mailing address and you can send some of that extra cash to me!
Old 09-04-2009, 12:22 AM
See I'm gona end up doin a complete custom dash. With all new gaugess and for the seats the bench is gettin swapped out for sum dodge charger seats so I figured it would b easiest to just got with a new wiring kit...
Old 09-04-2009, 09:46 AM
I would guess that even a custom dash will use the same wires that are already in the harness - illumination, gas gauge, oil press, temp, charge, brake, etc. I assume you'll be keeping the turn signal and ignition on the column. Again, sounds like it's much easier to simply change the dashboard connector on the stock harness. Your money - your call.
Old 09-04-2009, 10:28 AM
302 Z28's Avatar
The Painless kits use GM color codes and IMO would be the easiest to install in a Chevy. I have to agree with the one comment on spending $350+ on a rewire kit vs $35 for a manual. Unless your wiring is a total wreck that is the way I would go. On the other hand a rewire will give you the opportunity to improve the wiring by adding relays for such things as power windows, power door, brighter headlamps, and other high current applications that a wiring kit does not address.
Vince
88 Caprice tazman87 Hotrodding Basics 6 03-08-2009 05:15 PM
automatic to manual transmission conversion for a 1984 caprice classic Adrianc1094 Transmission - Rearend 2 01-19-2009 09:32 PM
5 on 5 bolt patern for a '88 Caprice mb9900 Suspension - Brakes - Steering 15 09-25-2005 01:58 AM
Parts catalog for a 75 caprice classic hotrodgrasshopper General Rodding Tech 2 07-10-2005 05:26 PM
Transmission 81 Caprice classic beetle9 Transmission - Rearend 4 05-09-2002 07:42 AM
