reworking 350 heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2008, 01:28 AM
reworking 350 heads
what can people tell me about reworking standard 350 heads. can do a lot of work myself on them and just want to tid up some standard heads to get the most out of mild 350 woring in 3000 to 3500rpm range and topped out at 4500rpm. was thinking of just tidying up ports for better flow with high performance vavle springs and installing screw in rocker studs for roller rockers etc. fuel economy and good mid range torque are the main criteria. got pop top pistons so don't want to go smaller in chambers and bump compression up.
Old 11-04-2008, 06:22 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Moving to the Engine forum
Old 11-04-2008, 09:31 AM
Well, personally, I wouldn't do very much to them... the only thing I would do is do a little pocket porting below the valve seat and shape up the material around the guides... other than that... as long as the guides and seats look check out ok then I would call it a day. If the seats are wide or the guides have too much play when a valve is inserted then have a shop do a 3 angle and put in some guides. Stock springs will work for a cam that's 'all in' by 4500. Besides, that's probably close to where a stock GM 350 signs off anyways, (maybe more like 4,000).
Screw in studs are only necessary if you are turning some rpm consistently or you have open spring pressures surpassing the 300lb marker. You don't need them just because you are going to run roller rockers.
Old 11-04-2008, 09:51 AM
DaSouthWon's Avatar
I put up the tools against$300
If you've never ported heads before, do your research before you start grinding on them. I would just look in the ports for excess casting flash and large rough spots and try to remove that. To smooth or to much widening of the port can be bad and hurt performance if your not sure of what your doing, especially on the intake side.
Old 11-04-2008, 11:00 AM
There are many good books on the subject, one I recommend is "How to Build & Modify Chevrolet Small-Block V-8 Cylinder Heads" by David Vizard. This will lay a very good foundation for understanding the Chevy head and what does and does not work with them.
Bogie
Old 11-05-2008, 02:01 AM
350 heads.
thanks for comments. think i'm on right track with things. need to change rocker studs as standard ones are too small to fit the roller rockers i have so may as well use what i already have. anyone got ideas on best castings for this application. while not high revving engine will be working hard as they do in boats with constant revs for long periods. so heads that are prone to cracking not a good choice. reading a lot on here about all different types and getting a bit confused what might work. weight not an issue just good solid reliability keeping in mind i want to stick with 76cc chambers to keep compression ratio under control.
Old 11-05-2008, 02:17 AM
techinspector1's Avatar
Wiki Edits: 326
"487" 3973487, OR 3973487X. The regular casting was found on the 1971-1972 350 LT-1 engines, had 1.94/1.50" valves, 76CC combustion chambers, DO have accessory holes, intake port volume should be 161CC's, exhaust port volume should be 65CC's. The 487X had 2.02/1.60" valves.
"441" 3932441. This head was found on the 1969-1970 350 engines (255hp 350), it was a decent flowing large chamber head. It had 1.94/1.50" valves, 76CC combustion chambers, DO have accessory holes, intake port volume should be 161CC's, exhaust port volume should be 61CC's. Not to be confused with 3923441, which was a 1.72/1.50" valve, 327 truck head.
http://cgi.ebay.com.au/BRAND-NEW-CHE...1%7C240%3A1318
Old 11-05-2008, 08:01 PM
Banned
If you're looking to max out at 4500 RPM's and good milage, you may want to actually add some material, you can use a variety of methods, usually welding or epoxy to do it, by filling in the voids and smoothing out the turns you'll increase air velocity and this is very important for low end.
I ported out a set of Vortec's that I'm using for a max torque engine, but I removed as little as possible as opposed to a max hp engine where you want to increase the volume a little more for upper RPM range.
Just try to keep the runner as small as possible with smooth turns and as few of turns as possible.
305 vortec heads vs 350 vortec rimracers Engine 6 04-02-2007 09:41 PM
olds #5 head johann Engine 1 07-30-2006 11:05 PM
Questions about chevy 350 heads. rayzorsharp Engine 11 04-27-2006 08:36 AM
350 Different heads Nobodyknows Engine 2 04-13-2006 08:03 PM
350 heads babygene41042 Engine 2 06-08-2004 09:10 PM
