Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rhodes lifters?
Thread: Rhodes lifters?
Old 03-09-2004, 12:00 PM
Roy_67_SS350 Roy_67_SS350 is offline
Rhodes lifters?
Hey All,
You may remember me posting about my engine combo not having sufficient low end torque for my needs, probably due to my cam selection. I'm running a Comp Xtreme Energy 268, Performer RPM intake, edel heads etc etc.
Anyone used the Rhodes lifters? Can I believe their advertising?
I have seen a magazine dyno test where they were showing improved low end torque av a similar engine to mine using them?
I see PAW sells them and that they're not that expensive.
I'm on a real tight budget now, and can't really afford a higher stall converter (probably need 2800 but have 2200) and a lower rear end gear (have 3.31 and probably need 3.73). Those things are off in the real distant future right now...
Just wondering if I could use the Rhodes lifters to help the power down low and if I could use them without changing my camshaft, which btw has about 3k miles on it.
