Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rhodes lifters?
Thread: Rhodes lifters?
Old 03-09-2004, 01:12 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
in your case, with the smallish cam, they likely will improve low end power, but I doubt they will as much as you expect, some have installed them on real big cams and couldn`t tell any difference, the lifters will tick like crazy at idle like a solid lifter cam would, which can get annoying, so instead of spending the cash on the lifters, I would just order a comp cams H268, with 218 duration, 454 lift, and a mild lopey idle without the loss of low end torque, for the price of rhoads lifters, you could order the new cam, resurface the lifters you have, and come out about the same price wise.
