Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rhodes lifters?
Thread: Rhodes lifters?
Old 03-10-2004, 10:37 PM
firechicken383 firechicken383 is offline
Yes, of the XE274 or XE284, I would use the 274. Personally, I would still go with more compression, unless your wanting to use the cheap grade gas. You have aluminum heads, you could run over 10.1 easy with 93 grade.
