Rhodes lifters yay or nay? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-23-2010, 07:13 AM
4 out of 5 posts
Shane
  #17 (permalink)
Old 12-14-2012, 04:10 PM
I purchased a 69 corvette 427 390 HP that was being restored and never been started since restoration and engine rebuild. I didn't know the engine builder and previous owner had installed rhodes lifters in it. Man was I shocked when it started. I thought the engine was coming apart, but it had good oil pressure. Its a very bad sound and I hate it, Maybee it will be quieter with the hood on. It does seem to have a lot of low end torque and power.I just don't think I will be able to stand the awful noise. This car has stock mufflers and is very quite so all you hear is the lifters.
  #18 (permalink)
Old 12-14-2012, 04:27 PM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by DoubleVision View Post
This thread is 7 years old. We should`ve carbon dated this one.
Still good info. I used 'em in a 454 to tame the cam. Worked well, sounded like solid lifters to me.
  #19 (permalink)
Old 12-15-2012, 10:17 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I used a half set (the intakes only) on a Pontiac 455 w/a fairly big single pattern cam. Worked like a charm. Noise? That's music.
The Following User Says Thank You to cobalt327 For This Useful Post:
techinspector1 (12-15-2012)
  #20 (permalink)
Old 12-15-2012, 10:58 AM
Wiki Edits: 326
For some reason, my mind wouldn't have come up with that fix. I wouldn't have considered using them on the intake only. Thanks for that.
  #21 (permalink)
Banned
they use the same thing for todays var. valve timing.. only a ecu and senders control it now..
same basic idea..
  #22 (permalink)
Old 12-15-2012, 11:28 AM
hcompton's Avatar
Old & Furious
I am a little reluctant to try them on modern dual pattern cam. With sharp ramps and designs looking for more power under the curve may not react well to roads lifters but havent tried it.
They do work good for long duration older style single pattern cams. But usally used in the street sizes larger cams race cams do not respond well.
  #23 (permalink)
Old 12-15-2012, 12:00 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
And you've tried them?
  #24 (permalink)
Old 12-15-2012, 07:43 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
Curious.Rocker studs,roller rockers,rocker ratios??.
  #25 (permalink)
Old 12-15-2012, 08:41 PM
Bye Jerks
I never cared for them. I don't use them.
307 yay or nay DeathRattle Engine 9 03-25-2008 10:24 PM
Kobalt Paint Gun, Yay or Nay? Gokussj5okazu Body - Exterior 8 02-08-2007 10:35 PM
Rhodes lifters Echofive Engine 2 06-17-2004 11:58 PM
rhodes lifters & 1.6 roller rockers? KeithB123 Engine 1 03-21-2004 10:57 AM
Rhodes lifters? Roy_67_SS350 Engine 23 03-12-2004 07:39 AM
