Rich - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2006, 12:08 PM
Rich
I am researching the kinds of bench seats that will work in my 1939 Ford Tudor Sedan. I have a set of mid-60's T-bird buckets in it now and I want to go back to a near original bench seat. Thanks for your ideas.
Rich
Old 05-17-2006, 12:49 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
I can't think of any stock split bench seats off of the top of my head as I used T-bird buckets in mine when I had it. I am sure some of the present 39-40 owners will be able to help you. Here are some links to aftermarket seats. They aren't inexpensive though.
Glide Engineering has three different custom split backs for your ride.
http://www.glideeng.com/
Wise Guys has them as well.
http://www.wiseguys-seats.com/catalog_frame_foam.html
Tea's Design as well:
http://www.teasdesign.com/catalog/
Old 05-17-2006, 10:31 PM
PrimeMover's Avatar
Sittin' on top of the world...
The other option is to measure the car up. Probably around 50-54 inches wide will work, then hit the late model wrecking yards with tape measure in hand.With a little finagling and a mig welder, mounting bracket can be made to order for just about any seat out there as long as the doner seat starts off at the right hieght or a little lower then you like . Too high isn't doable.
modifying that too rich edelbrock 1405 carb? TVR383 Engine 23 12-03-2009 09:19 PM
Q-JET idles to rich 46 chevy pickup Engine 4 04-16-2006 07:42 AM
Correction 1-7 & 4-6 rich, Holley solidaxel Engine 11 09-29-2005 09:14 AM
Need help -- SBC running rich all of a sudden jodz Engine 6 09-05-2003 08:59 AM
edelbrock carb. still too rich! TVR383 Engine 9 09-03-2003 02:27 PM
