Richmond 5 speed, 56 Chevy and shifter - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2005, 10:53 PM
Does anyone know if there's a shifter available that'll work with the Richmond 5-speed in a '56 Chevy having a bench seat? I know Hurst makes a Competition Plus shifter but it's for a T-10. Model Number: 3913780.
I would think there's some combination of handle, shifter and linkage that works without me having to "cut out" a notch in the bench seat. Yeah, I know bucket seats would solve the problem but I'd rather not.
Old 08-28-2005, 05:22 PM
New Member
Richmond 5 speed...
Since the later Hurst shifter handles are all bolt on, you should be able to use the "hockey stick" handle for a ST10 or Muncie on a Hurst shifter for the Richmond.
Barring this, you could also weld one up from a few swap meet handles to clear the seat also.
Might also want to check with B&M for a shifter.
Tom
Old 08-28-2005, 06:40 PM
larryblack's Avatar
Certified Lead Foot
Hurst sells all shifter handles as seperate parts.
Go to hursts web site and look up the number.
You have to go to www.mrgasket.com and click on the hurst link there.
The catalog can be down loaded for free.
Old 08-28-2005, 08:00 PM
302 Z28's Avatar
A buddy of mine has the same combination you have. He fabricated a shaped shifter handle from stainless that goes foward then sweeps back.
Vince
5 speed tranny with forward shifter? Warm_Spit Transmission - Rearend 2 08-13-2003 08:09 AM
Replacing Borg Warner T10 with Richmond 6 speed beazil Transmission - Rearend 3 05-16-2003 08:59 AM
Still looking for help on installing a ZF 6-speed in a 56 Chevy balweav Transmission - Rearend 0 04-03-2003 04:43 PM
Retro fit a ZF 6-speed in a 56 Chevy with a bench seat balweav Transmission - Rearend 1 03-13-2003 04:57 PM
GM 6 speed - shifter chevypu Transmission - Rearend 1 03-13-2002 05:21 AM
