richmond 6-speed? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2002, 07:13 PM
chevyelc81's Avatar
Post richmond 6-speed?
A guy told me that the richmond 6-speed tranny has straight cut gears and its dezigned to be slammed through the gears at a certain rpm without using clutch...so he says . Is that true??? He also mentioned that if you drive it easy, that it will wear out quick because of its dezign <img src="graemlins/drunk.gif" border="0" alt="[drunk]" /> . I personally don't believe that, It just dosn't make sense that it would wear out by driving it easy. Is anything this guy is saying true????
Old 10-23-2002, 10:14 AM
SJFast's Avatar
Post
There might be something here that will help :
http://home.att.net/~ncarboni/TrannySwap.html
Good luck !
