Richmond PowerTrax Locker - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2007, 07:22 AM
I have a 68 Camaro with a 8.5in 10 bolt that I just installed a 3.90 ring and pinion with a Richmond PowerTrax No Slip locker in the carrier. The car is running a SB 350 with a turbo 350 trans, 2400rpm stall and CalTracks. I thought this would provide a better positive traction unit for good traction off the line over a standard positive trac unit. However, all I'm seeing is wheel spin on the right side - a single black mark, not dual black marks as if both wheels are pulling. If I jack up the car and turn the rear wheels, both turn in same direction as if locked. Can anyone offer any siggestions as to why only one wheel pulling? And offer advice on a better positive traction unit I could change too. Thanks!!
Old 08-06-2007, 07:30 AM
Not A T 25's Avatar
Takes Guts To Cut One Up
Did you follow the installation checks to be sure it was set up correctly? There are specific test procedures that can determine what is wrong. If you go to their web site you can get them there. Sounds like you have something installed incorrectly. I have the same unit and never have this problem the only issue I have is with the clunk when turning a corner under power which I have been told is the unit unlocking.
Success is getting what you want but happyness is liking what you get.
Old 08-06-2007, 09:41 AM
I had the unit installed when the gear set was installed. I had a 4x4 driveline shop do the install, and asked if they were familiar with this unit. Owner said he had installed several before. I will look for the checklist you mentioned. I just thought maybe it was disengaging from the force at take off and not locking up. Are you saying you don't have this problem and are spinning both wheels? Thanks Again.
Old 08-06-2007, 10:09 AM
Not A T 25's Avatar
Yup no problem leave double tracks it could be a dragging brake on the rear which is simulating a turn I think that would be possible.
no-slip powertrax??? elcaminodragster Transmission - Rearend 1 05-12-2007 01:16 PM
Powertrax No Slip by Richmond BuddyK Transmission - Rearend 3 12-02-2006 02:12 PM
No slip Powertrax noise is it excessive Not A T 25 Transmission - Rearend 10 08-10-2006 11:29 AM
Powertrax locker 68 GTO Transmission - Rearend 2 06-08-2005 07:17 PM
Powertrax Locker: 1/4 mile time increase? purple1967camaro Transmission - Rearend 3 04-12-2004 08:23 PM
