ride height - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2009, 05:57 PM
ride height
I have a question about ride height changes before and after replacing control arm bushings. I recently replaced the upper and lower control arm bushings on my 73 vette - the new bushings are the polyurethane type. The nose of the car now seems to sit a couple of inches higher. The gap in the front wheel-wells also seems about two inches more than before. I am also finding that I need to add perhaps too many shims to achieve a slightly negative camber.
Is reducing the spring height an acceptable way to correct this? Would a shorter spring height make a difference to the camber?
Thanks
Old 12-23-2009, 06:40 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
If you didn't, you need to torque all of the suspension bolts with the weight of the vehicle on the tires.
Old 12-23-2009, 08:01 PM
Or maybe a spring came out of it's pocket. The only way a bushing would raise a car is if it is bound up.
Old 12-23-2009, 08:25 PM
Thanks for the replies. Yes, I did torque everything once the vehicle was resting on the wheels. The statement about the spring not being fully in the pocket may be pertinent. It is pretty hard to see if the springs have set in properly. If the spring is not set properly, then both of them must be as both sides look the same.
Old 12-24-2009, 07:36 AM
loosen the cross arm nuts , bounce on the front end a few times, make sure it is settled , retighten to specs.
just a thought .
1937 Ford pickup ride height magnum2u General Rodding Tech 7 01-01-2007 03:50 PM
setting ride height for suspension swap pigmechanic Hotrodding Basics 3 12-21-2006 11:25 PM
How Determine Ride Height locomark Suspension - Brakes - Steering 1 08-15-2005 04:16 PM
problem with ride height!!! brian400ex Suspension - Brakes - Steering 3 04-17-2004 05:22 PM
raising rear ride height 67_Deuce Suspension - Brakes - Steering 5 01-18-2003 11:19 PM
