ride height - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2012, 01:38 PM
ride height
I further researched the springs I put on my chevelle. they are moog 6330. the install height is advertised at 11.25,load 1827,spring rate 293,free height 17.5 but my ride height is so high I need to take out shims on the right side to properly align the front end. problem there are no shims to remove. this is why I asked about cutting them. I know different springs are probably the right way to go but project budget has run dry for a while and cruise in season is fast approaching. So does anyone know about how much drop one coil is worth? Thanks
Old 02-23-2012, 07:36 AM
Every car is different on how it responds to cutting springs, etc. And it makes it worse when you add fiberglass hoods, etc. Aluminum heads, etc. I would cut half a spring at a time. Keep in mind when you torque down the A-arms, etc. The suspension needs to be loaded first. Look out for any binding of the bushings, etc.
Old 02-23-2012, 08:04 AM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
how far do you want to drop the front?
how long have the springs been in the car?
they will settle some
ride height biscuitville Suspension - Brakes - Steering 4 12-24-2009 06:36 AM
Setting ride height? BigBlockT General Rodding Tech 2 04-07-2009 03:39 PM
ride height? BigBlockT General Rodding Tech 2 01-26-2009 03:11 PM
Ride height 47fleetline Suspension - Brakes - Steering 1 11-05-2005 07:25 AM
Ride height delimma wally8 Suspension - Brakes - Steering 8 01-03-2005 02:15 AM
