Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ride hieght
Thread: ride hieght
Old 02-07-2006, 10:26 AM
BillyShope's Avatar
BillyShope BillyShope is offline
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
Yes, "ride height" is usually used without a specific numerical value in mind. "Minimum ground clearance," however, IS associated with a vertical height and is often included in a tabulation of vehicle parameters. That "minimum" can occur anywhere, but it's a good idea if its value is a little greater than the highest speed bump you'll encounter.
http://home.earthlink.net/~whshope
