ride hieght - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2006, 06:12 AM
ride hieght
At what point on a car do you measure ride hieght from? , and Where is a good resource to find ride hieght for 73 caprice 2 door ? . I trying to determine how much it might of settled after 30 + years because I don't want to end up with
3 or 4" when I'm only looking for 1.5-2" lift .
Old 02-07-2006, 09:48 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Usually its just a reference point. I measure up to the wheel opening or a molding strip for a before/after reference.
If you buy a shop manual for the car, sometimes they have body and frame layouts that will tell you. They'll give you points where you can measure from the floor up to the frame.
Old 02-07-2006, 10:26 AM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
Yes, "ride height" is usually used without a specific numerical value in mind. "Minimum ground clearance," however, IS associated with a vertical height and is often included in a tabulation of vehicle parameters. That "minimum" can occur anywhere, but it's a good idea if its value is a little greater than the highest speed bump you'll encounter.
http://home.earthlink.net/~whshope
Old 02-07-2006, 09:04 PM
techinspector1's Avatar
Wiki Edits: 326
I have found that the minimum practical ground clearance for a street driver is 4". Before I get flamed, remember I said "practical".
Old 02-19-2006, 02:22 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
All decent front end alignment shops have specs for every car so that they can measure the ride height prior to aligning. These specs are for factory tire sizes and inflation pressures. Some charts indicate suspension to chassis dimensions.
Increasing Ride Height Slightly - what are my options? hduff Suspension - Brakes - Steering 8 10-19-2004 07:44 PM
Hydraulics vs. air ride flamedfordbronco Suspension - Brakes - Steering 16 01-24-2004 08:46 PM
Intel Ride Kit Dutchman Suspension - Brakes - Steering 4 07-16-2003 11:10 AM
I wanna ride in a blown car! HemmiGremmie Hotrodders' Lounge 11 04-04-2003 12:06 PM
america's ride 2002 38 special Hotrodders' Lounge 0 08-26-2002 12:11 PM
