right cam on baby-blown 350 sbc ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2010, 02:32 PM
Hi guys,
first of all i'm from Germany, and really glad about you
gearheads having much more experience in SBC TUNING
than most of our garages.
My problem: Have a 350 with ported iron heads,
72 chamber, 8,5 comp/r, a 142 Weiand blower
and a 750 Holley DP between.
The cam is a 288/298 ...?!? Nobody knows...
Don't know whether it is really ideal for this package.
What do you think? What performance to expect?
Thanks a lot
Old 07-08-2010, 03:10 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Triple post.
Old 07-08-2010, 03:47 PM
I think it is this one:
Crower 60918 288/298 214/224 .444/.467 .489/.514 112
but not sure
Old 02-01-2011, 04:29 AM
Ok, found out:
Itīs the Crower 00904
288/298 Adv. Duration
444/467 Gross Lift
What do you think?
Old 02-01-2011, 06:21 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A good match to your engine and blower, IMO. Will be streetable w/a nice wide powerband. The LSA is 112 degrees, too (good for the blower). I wouldn't hesitate to use it.
Old 02-01-2011, 06:25 AM
Thanks.
How much horse could be possible?
Old 02-01-2011, 06:41 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Depends on what the OD ratio of the blower is, and that is largely dependant on the fuel octane or knock resistance. I would imagine 400 plus to be easily accomplished w/good pump gas, though.
Old 02-01-2011, 07:15 AM
The OD ratio is standard 1,95 i think. Driving 100 Octane and
30 degree max.
Old 02-01-2011, 08:34 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The point where you reach detonation with your particular combination of parts and tolerances will be what defines how much SAFE power you will make.
The octane rating number you see listed on the pump differs from what we see in the states. Your fuel octane is very likely calculated using the Research Octane Number (RON) method. In the US and Canada, the octane is calculated by using the "Anti-Knock Index"- derived by averaging the RON and MON (Motor Octane Number).
So, unless you've already factored this in when you say "100 octane", your octane- as we would figure it stateside- would be more like 94-96.
Quench is also important to octane requirement/detonation resistance.
Depending on how much boost the blower makes, your effective CR can be upwards of 12:1 w/as little as 6 psi.
Other factors important to how much boost you can effectively run is the ignition timing curve, ambient air conditions, vehicle dynamics like weight, gearing, how it is used, etc.
So to say the engine will make "X" amount of HP is beyond what I can estimate except in a broad term, w/o having access to simulation software.
Should you want to use a simulation program, the following was posted:
Originally Posted by techinspector1
DYNOSIM REQUIRED DATA....
Bore
Stroke
Rod Length
Cylinder head flow, intake and exhaust 0.100" through 0.700" or whatever the mfg gives for range
Intake valve diameter
Exhaust valve diameter
Static compression ratio
CFM, type of induction (2-bbl, 4-bbl, TBI, TPI)
Intake manifold type, mfg (single 4-bbl, two 4-bbl, one 2-bbl, three 2-bbl, individual runner Weber, mechanical fuel injection, low-rise, high-rise, tunnel ram, dual-plane, single-plane, part no. if you have it.
Exhaust system (be specific, primary tube size if long-tube headers)
I have quite a library of CompCams (give me part number, not grind number) in my files, but if you are using another mfg, I'll need type (flat, roller, solid, hyd.), intake valve lift, exhaust valve lift and the following timing info and at what tappet lift the info is valid...(0.006", 0.050") I can calculate from 0.020" if I'm given enough information, but again, that takes my time.
Intake opens ______BTDC
Intake closes ______ABDC
Exhaust opens______BBDC
Exhaust closes______ATDC
Old 02-01-2011, 08:41 AM
thank you very much
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Why not a 350 sbc? bowtieorbust Engine 29 09-05-2008 09:43 AM
Cam bearings 350 chev, cam wont fit in front bearing???? JD's camaro Engine 5 02-07-2008 03:33 PM
what size carbs on my blown 671 sbc 350? darkostoj Engine 2 12-18-2007 12:30 AM
question on cam & oil pump install chev 350 solowookie Engine 16 04-03-2002 04:25 PM
