Right cam for my SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2010, 05:32 PM
Madmax305's Avatar
Will this be a good cam on my 67 el camino. It has a sbc 350, rhs torker heads, 180cc runner, 64 cc chamber, (about 9.2 compression), holley 670, edelbrock performer eps intake, headers, 3.55 gears, stock stall converter on turbo 350 and my car weights about 3200lbs. This is a daily driver/cruiser. I like to go to car shows and to be honest, I am not really looking for power as to much as the sound of a good lopey/thumping cam. This cam was recommended by a tech from Comp cams. I prefer to stay with hydralic flat tapper cam vs roller....
http://www.summitracing.com/parts/CCA-CL12-238-2/
Old 02-16-2010, 05:52 PM
my87Z's Avatar
Veteran/Firefighter-Paramedic
X2
you will hear a little bit of a lope in the idle, you'll be able to hear the the motor is not stock
Old 02-16-2010, 06:28 PM
Madmax305's Avatar
Any idea on what the stock stall converter is on a turbo 350. I was hoping to put the comp thumper cam in my 350. Any suggestions on a higher stall converter?
http://www.summitracing.com/parts/CC...4/?image=large
Old 02-16-2010, 06:39 PM
my87Z's Avatar
this is just my opinion but stay away from comp cams thumper cams, they do just what they say thump, but dont give power with that thump, it's like false advertising. as far as stalls go i dont like putting anything less than a 3000 stall in a vehicle if i have to put one in, personaly i've found that a lot of 2000-2500 stalls are just modified stock stalls, but you typically want to have a stall speed about 500rpm above where your cam starts making it's power
ie; 2000-5500 cam= 2500 stall, 3000-6000 cam= 3500 stall
Old 02-16-2010, 07:40 PM
Hello well I have been where your at before and if you want that racy idle then you will have to get all the right stuff to go with it along with rear end gear ratio etc. If you want something that has a noticeable idle and still be fun to drive around town with out any issues then get the cam comp recommended. At 218/224 @ 30 duration its quite more then stock and it will give your 350 a nice lope to it without being extreme and will make way better power then a thumpr cam.
Stay away from the thumpr cam. I had one and after one year I got rid of it on ebay. I have a 350 with a little more then what you got but not by much and I am running a slightly bigger cam then the one comp recommended you but not by much and it sounds good and I can still cruise around with out issue.
Big racy cams are more for the track and a weekend type thing. Please don't make a mistake and over cam your engine. I had to learn through several years of problems getting carb to work right, timing, spark plugs and other things. Just get what you really need and be happy. Trust me and from others.
Old 02-17-2010, 08:14 AM
Madmax305's Avatar
What cam are you running? Thanks for all the reply guys!
Old 02-17-2010, 10:04 AM
Madmax305's Avatar
Would this cam work with my set up and would it give a more agressive idle than the xe262h? The tech info says this is the largest cam for a stock converter.
http://www.summitracing.com/parts/CCA-CL12-242-2/
Old 02-19-2010, 04:54 PM
Well that would work good with your setup pretty well but I would not go any bigger then that. That cam will give you good bottom end as well as some good top end as well. Your rear gear ratio should work good with it as well. I am going to swap out my 4.10 to a middle gear ratio soon like that as well.
I have a same size cam as that in my engine now with world sportsman 2 heads and edelbrock performer rpm intake and it idles with a nice lope at around 800 rpm and I have yet to have any issues cruising around town and its a breeze to tune my 600 holley carb I have on my 350 now. My cam is a crane powermax hydraulic roller cam but it will sound about the same.
The xtreme energy cam actually has a faster ramp rate then mine so it might be a hair more lope to it. Trust me if you use that cam it won't sound like stock by a long shot. It's not a nascar racy type idle but it sounds good when you fire it up. Also your stock converter will work but if you have a chance to get at least a 2000-2200 rpm stall that would make it work better. I got one from jegs for 120 bucks and it does excellent.
Hope that helps you out on a choice.
Eric
Old 02-19-2010, 05:07 PM
Schoust's Avatar
Hey Max I am in the very same boat as you but my cylinder head selection is not in stone just yet. I have plans to use a set of early. But 2.02 / 1.60 valved heads that have been ported and all the machine work done the only problem is I do not know what they flow or what they are capable of so that makes it tough to mach a cam up with them. The cam I have that came with this engine is a Crane Powermax HR-276-2S-12 IG it is a fairly mild grind that at first attracted me because I was thinking about a small turbocharger? But as of now the wallet says sell the 112 shaft in favor of a 110 shaft with a bit more lift and duration. I am also entertaining Vortec heads if I can find some locally? If this cam is of interest let me know maybe we can deal?
Old 02-20-2010, 10:58 PM
Madmax305's Avatar
Thanks for the info guys, Looks like I will be getting a 3000 stall.
Old 02-21-2010, 07:11 AM
why install a cam with more duration on the exhaust than intake? That is a fix for a poor flowing exhaust port and/or poor flowing exhaust system. You have headers and a good set of aftermarket heads so no need for all that exhaust duration. The engine will make more power with less exhaust
I would avoid xtreme cams as they are extremely likely to go flat and make a noisy valve train.
A cam like a comp 268H or 270H would be better. same intake as exhaust duration and slightly softer ramps so it will be less likely to go flat and make noise. Plus these cams will work well with 9.2:1 cr and a 3.55 gear. Will make a little less power due to the softer ramps but is but less likely to go flat and chew up the engine bearings.
use an oil additive with your new cam. www.zddplus.com
The stall is a tricky choice. 3000 rpms would give to the best performance but will have that "slipping feeling" at more than 1/2 throttle. So, driving around town will feel like the trans is slipping but the highway should be ok with that 3.55 gear since 3000 rpms comes quickly. Yes, most 2000-2400 stalls are poorly modified stock converters but they work. Stock stall rating is in the 1600 rpm range, but where it really stalls depends on gear, weight, and engine torque.
light car, higher numeric gear, small engine lowers the stall
heavy car, lower numeric gear, big engine increases the stall
fyi, if you plan to pull a trailer with your car/truck then don't put in a bigger converter. Just use a cam that can use the stock converter. 260H or 268H.
A 2400 stall will turn into a 3000 stall with a trailer (heavy car increases the stall).
Old 02-21-2010, 07:45 AM
Banned
Ditto.
I would also add Isky makes some good single pattern cams in this range. And if you want more lift then change the rockers to 1.6's.
Old 02-25-2010, 04:21 PM
Cam selection.
I would stay with single pattern cam design. For mild SBC performance applications they seem to just work better. Most of the guys here know what they are talking about. Your set up would really work well with a smaller cam like a compcams 268 or 260. The 268 is a great compromise, this is a fairly heavy car and you need torque to move it. The 268 will sound good and perform very well. I think you would be really pleased.
Through the years I have come to a very enlightening conclusion. It's not about the cam you want, it's about the cam your engine wants. I have a system, find the cam grind/specs that is about right and then buy the next smaller grind. yea, sounds stupid but it works! It's worked really well for 40 years. In selecting a camshaft, bigger is not better.
SBC 267 cam Niko1080 Engine 9 07-29-2009 05:34 AM
Lunati cam and 305 sbc questions in a Frankenstein low budget rodder Engine 13 06-30-2009 04:55 AM
Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? killerformula Hotrodders' Lounge 20 08-31-2008 05:12 PM
350 sbc cam suggestions please sfd771 Engine 1 07-30-2004 06:25 PM
IGNITION and CAM TIMING sum87mustang Engine 3 07-11-2003 07:52 PM
