-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   Is this the right closed cell foam to get for door panels ? (http://www.hotrodders.com/forum/right-closed-cell-foam-get-door-panels-201933.html)
benjhagen 07-12-2011 09:56 PM
I read dantwolakes thread about door panel how to.. and I read to go to this site to buy the closed cell foam for my door panels..
is this the right stuff ?
Komatex Sintra PVC Foam Sheet
.125x24x48
found it on this site..
site..
Thanks guys.. I just want to make sure I get the right stuff
Centerline 07-12-2011 10:15 PM
I believe what you want is called "sew foam". Its specially made for upholstery and has a special backing on it so you can sew it to whatever material you're using.
This is sew foam
Centerline
HotRodsAndHemis.com
The only place you'll find a helping hand is at the end of your own wrist" - Joe "Dr. Olds" Mondello
benjhagen 07-12-2011 10:18 PM
Thanks for the input but I dont think sew foam is closed cell foam. I need it so I can carve channels into it so I can glue the foam into it.
However I think I will use sew foam to do my tuck and roll and then glue it to my door panel.. I think. Im still learning.
Thanks for the help
mordachai 07-13-2011 06:58 AM
the sintra is a foamed pvc sheet, not as strong as reg. pvc but it's lighter and bends easier. easier to cut sand etc, but it's a rigid 'foam'...
it's not the foam you're looking for, if you look for landau foam you'll find what you need.
hope that helps
pocket5s 07-13-2011 08:10 AM
would that foam be similar to airex foam? The Super Chevy mag is building a camaro and an interior shop used that foam for building out the dash and such to be later covered with fiberglass. They used it because it was rigid enough to be screwed together until the final covering. However I couldn't find that stuff anywhere, online or otherwise so I was looking for a replacement.
DanTwoLakes 07-13-2011 11:11 AM
Sew foam is softer open cell polyurethane foam with a backer fabric bonded to it that will hold a stitch line. The closed cell foam you are looking for goes by the brand name Volara. It is very firm and is used to sculpt shapes for door panels, etc. CLICK HERE The Sintra or Komatex PVC foam board is rigid and is used for making door panels, etc. The Volara would be glued to the Sintra.
Airex is a type of PVC foamboard. It is generally used in marine construction in greater thicknesses like 1" or more sandwiched between fiberglass layers as a core to create lighter weight structures like hulls.
PVC foamboard is very versatile. It can be cut and shaped with ordinary woodworking tools, it can be heat formed, and can be glued together with gel type super glues.
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
