Is this the right closed cell foam to get for door panels ?
I read dantwolakes thread about door panel how to.. and I read to go to this site to buy the closed cell foam for my door panels..
is this the right stuff ? Komatex Sintra PVC Foam Sheet .125x24x48 found it on this site.. site.. Thanks guys.. I just want to make sure I get the right stuff |
I believe what you want is called "sew foam". Its specially made for upholstery and has a special backing on it so you can sew it to whatever material you're using.
This is sew foam Centerline HotRodsAndHemis.com “The only place you'll find a helping hand is at the end of your own wrist" - Joe "Dr. Olds" Mondello |
the sintra is a foamed pvc sheet, not as strong as reg. pvc but it's lighter and bends easier. easier to cut sand etc, but it's a rigid 'foam'...
it's not the foam you're looking for, if you look for landau foam you'll find what you need. hope that helps |
would that foam be similar to airex foam? The Super Chevy mag is building a camaro and an interior shop used that foam for building out the dash and such to be later covered with fiberglass. They used it because it was rigid enough to be screwed together until the final covering. However I couldn't find that stuff anywhere, online or otherwise so I was looking for a replacement.
Sew foam is softer open cell polyurethane foam with a backer fabric bonded to it that will hold a stitch line. The closed cell foam you are looking for goes by the brand name Volara. It is very firm and is used to sculpt shapes for door panels, etc. CLICK HERE The Sintra or Komatex PVC foam board is rigid and is used for making door panels, etc. The Volara would be glued to the Sintra.
Airex is a type of PVC foamboard. It is generally used in marine construction in greater thicknesses like 1" or more sandwiched between fiberglass layers as a core to create lighter weight structures like hulls. PVC foamboard is very versatile. It can be cut and shaped with ordinary woodworking tools, it can be heat formed, and can be glued together with gel type super glues.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ Last edited by DanTwoLakes; 07-13-2011 at 11:28 AM. |
| Recent Interior posts with photos |
| Can closed cell foam be butted together? | cboy | Interior | 28 | 11-14-2009 10:17 PM |
| Landau foam for door panels | jimchevy | Interior | 14 | 03-03-2008 07:56 PM |
| need help sanding closed cell foam. | RodFather | Interior | 3 | 04-26-2007 06:51 AM |
| foam for door panels | crownver | Interior | 9 | 02-25-2006 01:05 AM |
| closed cell foam/sculpting | vintage | Interior | 0 | 04-21-2002 04:23 AM |
