Right flywheel
Can someone please advise me if this combination will work. I have a 1989 fuel injected 460 out of an econoline E350 block ID D9TE-AB. This engine was an automatic that I want to convert to a manual transmission. My question is I have a 1987 manual flywheel RF-D9te-6380 off of a 1987 460 that I want to install on the 1989 auto motor and was wondering if the balancing will be correct? If I understand correctly they are both externally balanced so it should work. Any input would be appreciated. Thanks
1978 and earlier 460's are internally balanced, 79 and later engines are externally balanced. If you are not sure your engine is extrenally balanced, look between the front balancer and timing cover. If there is a small counterweight on the crank it is externally balanced.
| FLYWHEEL question: t-5 (V8) and 4.3L 5 spd flywheel | boneyard Buick | Transmission - Rearend | 1 | 07-20-2009 09:43 AM |
| FLyWHEEL QUESTION. 4.3L 5 spd flywheel work in t5 with clutch? | boneyard Buick | Engine | 0 | 11-17-2006 07:20 PM |
| Removing flywheel to converter bolts in a 1958 Chevy Impala 348 Cast Iron Powerglide | 1958imp348 | Transmission - Rearend | 9 | 11-22-2004 03:18 PM |
| Flywheel Inertia | BillyShope | Suspension - Brakes - Steering | 3 | 09-02-2004 06:44 PM |
| Flywheel balancing? | nomis30 | Engine | 3 | 11-25-2003 11:03 PM |
