Right size blower - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-08-2013, 02:47 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Originally Posted by ap72 View Post
If you want the best power anything ending in "-71" isn't going to get you there.
Are you kidding Ap? Define "best power", we're all ears!
I agree there are more desirable alternatives, depending on what you're looking for, but a roots blower will certainly get you there.
Semper Fi
  #17 (permalink)
Old 11-08-2013, 02:51 PM
Banned
their efficiency is very poor compared to any modern designs, takes more power to drive them and they produce less.
  #18 (permalink)
Old 11-08-2013, 03:06 PM
Originally Posted by 8Camaro9 View Post
i want it to look and be fast
Then ditch the GEN1 SBC/supercharger idea and throw a GEN3 LS motor and turbo in that thing.
  #19 (permalink)
Old 11-08-2013, 03:16 PM
Banned
you may as well try to teach a pig latin. This forum is for the old an outdated sbc. Sure its a poor design by modern standards but its all most of these people know and they'll never let go of it.
Hell people ask for a carb recommendation at least every other day- a freaking CARB?!?!?
  #20 (permalink)
Old 11-09-2013, 09:38 AM
NOlowrider's Avatar
US Navy-Retired
Originally Posted by ProStreetRob View Post
If your going for the best look/power then go with a polished 671 w/ low boost
If you main goal is power & efficiency then go with the 142 and more boost
And if you dont want anything sticking out of the hood go with a Procharger.
As already said any of those combo's will hit your goal
PS
THERE'S NOTHING LIKE A BIG *** POLISHED BLOWER
Pretty much sums it up.
  #21 (permalink)
Old 11-11-2013, 08:40 AM
We did several Whipple blower installations on some lower level Poker Run type boats. They were VERY easy to install, their quality was superb and they made a TON of power. Most of these were 383's with 93 octane and running a Mega Squirt system. One was a 427 SBC using an aftermarket block.
  #22 (permalink)
Old 11-11-2013, 09:08 AM
Banned
This is a good place to start!
a phone call to whipple would be a good second move.
  #23 (permalink)
Old 11-11-2013, 11:39 AM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
I agree It'll Get you there and more!!!!
Jester
  #24 (permalink)
Old 11-11-2013, 12:05 PM
QUOTE:
"Blower speed is determined by the belt-driven pulleys used on the front of the engine. The faster you spin the blower, the more air the blower moves. Unfortunately, this also creates heat. Lots of heat. Additionally, while internal clearances on Roots blowers are better than they'’ve ever been, internal leakage still occurs, which decreases the blower’s efficiency. The most popular of the Roots blowers are the 6-71 and 8-71 superchargers most often seen on Pro Street cars.
Centrifugals have become the fastest-growing supercharger segment in hot rodding, mostly for packaging reasons. The centrifugal is really little more than a belt-driven turbocharger. Centrifugals work on the principle of using an impeller spinning at extremely high speeds to accelerate the air and pass it through a diffuser to slow it down, creating pressure (and increasing temperature) as a result. The air is then piped to the engine intake.
One significant difference between a centrifugal supercharger and a Roots blower is that the centrifugal is a true compressor rather than an air mover. This means that the air exiting the centrifugal is already under pressure. This is measured in the centrifugal’s rating of 70 percent adiabatic efficiency versus the Roots’ less efficient 50 to 60 percent rating. One advantage of the Roots blower over a centrifugal is the Roots is a positive-displacement blower, which means it can come up on BOOST ALMOST INSTANTANEOUSLY ! , while centrifugals require time to “spool up” to create boost. As you can see, there are a number of variables that make the decision a little tougher.
A recent addition to rodding’s family of superchargers is the screw supercharger. The screw supercharger is a device originally designed as a large industrial air compressor. Norm Drazy was the first to employ the screw supercharger in drag racing, while another ex–drag racer, Art Whipple, has worked with the Auto Rotor Company to produce a series of street screw superchargers.
Designed as a dedicated compressor, the screw supercharger also enjoys a rating of high-70 to low-80 percent adiabatic efficiency as well as a compact size. The supercharger gets its name from its twin screws that inter-mesh inside a case to compress incoming air efficiently. The original Whipple blowers were small and intended for mild Chevy pickup applications, but Whipple has a larger screw supercharger that will be capable of 750 hp. " [END QUOTE]
Just a note you might be interested in:
I ran 2 Inch blower belts on my 471s and 671s on the street because they are much quieter then the 3 inch and I always carried a spare belt in the car, I ran 3 inch belts at the Drag strip !!!
Jester
The Following User Says Thank You to painted jester For This Useful Post:
AutoGear (11-11-2013)
gmc 6-71 diesel blower to 6-71 blower thats usable on a big block chevy dman16 Engine 10 08-11-2010 11:46 PM
What size carbs for this blower app? Overdriv Engine 8 10-02-2009 10:58 PM
blower pulley size kwopper07 Engine 3 08-11-2008 07:06 PM
Choosing blower size curtis73 Engine 5 11-26-2007 04:17 PM
Blower carbs..what size and whats the difference novawagon Engine 9 10-27-2003 01:45 PM
