rim fitting pcd HELP! - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2007, 04:04 PM
Hi,can anyone help,i have picked up some rims cheep listed as jag/chevy fitting pcd but on arriving home tried them on my jaguar axle and they dont fit CAN ANYONE HELP THEY ARE FIVE STUD MULTIFIT ONE PCD IS 140MM AND OTHER PATTERN IS 115MM,wheel stamped made in u.s.a. Any one out there got idea what yank axle they fit?
Old 02-05-2007, 05:28 PM
Well , in Yank measurement (which we refer to as inches) It is 4.5 and 5.5 inches . That is if that is the bolt pattern measurement and then it could fit several different Fords and Mopars .G'luck with yer Hotrod. swaZZie
Old 02-05-2007, 05:51 PM
I have Jaguar rims on my Camaro right now.It is the same bolt circle,4 3/4".
By the way the British invented the inch measurement.The Yanks followed.
Old 02-05-2007, 10:21 PM
Cheers swaZZie now i can sell quoting what they will fit thought most people would use only metric measurement now i prefer to use inches but i get mocked sayin its old skool but what the hell!
Old 02-06-2007, 05:51 AM
Thanx Paulo 1 for pointing out what was an obvious sarcasm . Unfortunately 4 and 3/4 is neither of those sizes . Hope I was a help 52prefect , g'luck with yer sale.
Old 02-06-2007, 08:51 AM
Just to be sure, these wheels have two separate bolt patterns? Most 5-lug wheels have slots (generically called uni-lug) and will fit 4.5 inch, 4.75 inch, and 5 inch.
FYI, the 4.5 inch is typically used on Ford and Chrysler mid-size cars (Mustang, Cuda, Torino, etc.). The 4.75 is the GM mid-size bolt pattern (Camaro, Chevelle, Corvette, Nova, and derivatives) and as was pointed out is also the Jag bolt pattern. 5 inch is usually used on the full size cars (Impala, Oldsmobile 98, Cadillac) and some half-ton pickups and vans. 5.5 inches is pretty much trucks only. I find it strange that a set of wheels would have only 4.5 and 5.5 bolt circles.
"Basics of Basics" Trial fitting parts MARTINSR Body - Exterior 4 02-23-2008 09:33 AM
measuring rim width cboy General Rodding Tech 5 11-12-2004 09:44 PM
Stuck front rim Forsaken502 Suspension - Brakes - Steering 6 09-17-2003 10:17 PM
water pump fitting leaking brian400ex Engine 4 03-22-2003 05:06 AM
Rim fitting Mirror Image Suspension - Brakes - Steering 1 03-02-2003 12:28 PM
