rims? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2002, 01:33 PM
Question rims?
Does anyone know how to polish rims at home? Thanks
Old 08-25-2002, 03:49 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
Polish from what to what? Cast aluminum, steel? what? Do you want a highly polish, satin finish, what, give me some ideas.
HK
Old 08-27-2002, 07:41 PM
Post
I have aluminum rims now. I would like to polish them to where they look like a mirror kindof. I don't want it to look like a ricer though. Give me ideas
Old 08-27-2002, 08:27 PM
Post
Sand paper and lots of elbow grease then get some polishing rouges and but a buffing wheel for your electric drill and go at them with the rouge and buffing wheel. My advice, don't do it, way to much work, but if you want to there you go. Just start out with a courser grit sandpaper then gradually work to 220 them use the rouges. Go from the coursest to the smoothest and buff it untill it shines like you want them too. Afterwards I recomend clear coating them for ease of cleaning and upkeep.
HK
Old 08-27-2002, 08:35 PM
41willys's Avatar
Blowin' it
Last journal entry: Running again...
Wiki Edits: 11
Post
I wouldn't go with anything courser than 220 at all. Maybe start out with that and work your way up from there until they start shining up. Then use the rouge and buff. They will be much shiner and you will see less imperfections. Good luck, watch those elbows.
Old 08-28-2002, 01:18 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Post
If the rims are pitted then you will have to sand. If not then use red scotchbrite and go all over the rims. You will have to get a high speed buffer and polishing compound made for aluminum. It comes in different grits. Check with Eaastwoods. They sell kits to polish rims. Also there are places starting to crop up across the country that will repair rims and polish rims. If you take it on yourself it will take awhile to do. Best to make it a winter project when there isn't much else to do.
Kevin
LZ rims, what car/year are they from?? hobbiesracer General Rodding Tech 1 10-17-2007 07:56 PM
Refirbishing 1973 and 1974 stock rims. topdogger Suspension - Brakes - Steering 2 09-26-2006 05:49 PM
gona pick up some new rims montea General Rodding Tech 4 10-16-2004 11:31 AM
Rims barbabart Body - Exterior 0 01-13-2004 01:02 PM
