We're winning the case!
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 02-23-2007, 10:24 PM
350olds 350olds is offline
rims for olds???
anybody know what rim size, offset, backspace will allow me to run a wide tire on my 71 cutlass. it is not tubed and i was looking to run a 295 or larger tire.
Old 03-05-2007, 03:45 PM
Deuce Deuce is offline
Deuce's barnstar
Wiki editor
Last wiki edit: Wheelbase database
I usually make me a plywood circle ... of the diameter of the tire I want to use ... and then drill the wheel pattern to it and bolt the plywood blank jig to the rear end ... then measure the distance between any offending inner/outer metal that may interfere ... and then I know how wide a tire and the offset I need ...
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "rims for olds???"
Refirbishing 1973 and 1974 stock rims. topdogger Suspension - Brakes - Steering 2 09-26-2006 05:49 PM
gona pick up some new rims montea General Rodding Tech 4 10-16-2004 11:31 AM
Rims barbabart Body - Exterior 0 01-13-2004 01:02 PM
rims... spankthru Body - Exterior 2 11-01-2003 05:17 PM
