Ring break-in? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-18-2009, 11:36 PM
i had my engine honed by a shop, that used a torque plate..
I also used a flat tappet hydruallic cam in my chevy 350.. so it got it's requisite 20 minutes @ 2000 rpm, then I drove the living **** out of it.. and it has more or less zero blow by.. i have a breather in one valve cover PCV in the other, and the engine is coming up for it's first oil change.. I foolishly forgot to write the milage down when I changed the oil after the break in period.. I think it's around 5000 now. (Been using a semi-synthetic oil) so I just let it be until it started getting 'black'.. and figure I'll change it now.
I broke in using Shell Rotella 15-40w due to it's high zinc content (that's good for flat tappet cams)
then after 500 miles on that, I changed it to Valvoline MaxLIfe 10w30 and haven't looked back since.. including over-revving the poor thing to 7200 rpm once...
my theory on break in.. is go or blow
  #17 (permalink)
Old 03-18-2009, 11:54 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Huge No-No is using any "STP"-type additive during break-in, or for the first 2k miles, just to be safe.
Generally speaking, no additives are needed- period, except for possibly zinc (for flat tappets), IMO.
Using the RIGHT ring compressor now! flynbrian48 Engine 4 02-18-2008 07:57 PM
Busted a bloody piston ring!!! flynbrian48 Engine 8 02-14-2008 09:28 AM
Piston ring Question (For Nitrous) Ratoflic Engine 0 04-19-2006 04:04 PM
piston help, and or ring help blake carstensen Engine 2 12-08-2005 08:25 PM
snap ring problem antiquebob Transmission - Rearend 7 04-30-2005 04:24 PM
