Ring Compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2014, 03:04 PM
Ring Compressor
I want to use a non-adjustable tapered ring compressor, to install my rings in my 390fe Ford. Stock bore 4.05 + .030 overbore = 4.80 (correct) ?
So what size ring compressor would work .... 4.90 ????.
I asked Summitt Racing what size they said 4.30. Does not sound right...
Old 03-29-2014, 03:08 PM
Typo..... I mean 4.080
Old 03-29-2014, 03:24 PM
Irelands child's Avatar
Use this one http://www.summitracing.com/parts/sme-90a4000/overview/ - as it covers 4.0 through 4.090. They adjust for size with a worm gear clamp and with mine being used a couple weeks ago, super simple.
There are no instructions (at least that came with mine). You slide it on the piston, snug the clamp some and squarely over the rings, protect the crank with some 2-3 inch chunks of tubing over the rod bolts, rotate tha crank 'down' oil the rings then tap in place while guiding the rod over the crank journal. It does take a 'feel', about two pistons worth
Dave W
Irelands child
The Following User Says Thank You to Irelands child For This Useful Post:
65 f-100 restore (03-29-2014)
Old 03-29-2014, 03:51 PM
Thank You Dave, You have made my day............Ed
Old 03-29-2014, 06:56 PM
Thought I could help a bit
That ring compressor is s-o-o-o much better then the old ratchet type. Just take your time on the process and it all falls in place. Arrange the ring gaps according to Ford or the ring or piston manufacturer, tighten the clamp slowly until you see the top ring end gap just about close and you are ready to 'shove' it in place with a few light to medium taps (that orange hammer inadvertantly pictured in my photo above - I just used the handle)
Dave W
Irelands child
piston ring compressor? 39chevy Garage - Tools 1 02-08-2013 11:16 PM
piston ring compressor recommendation GMR Engine 16 10-27-2008 06:22 PM
Using the RIGHT ring compressor now! flynbrian48 Engine 4 02-18-2008 07:57 PM
another way to get pistons in without ring compressor/. Rubberman2003 Engine 5 09-14-2003 08:27 PM
409 piston ring compressor Greg Fiandola Engine 12 09-07-2003 01:40 PM
