Ring Gap - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2007, 06:12 AM
Ring Gap
What should the ring gap be for a 77 Monte Carlo 350?
Old 12-27-2007, 06:17 AM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
A general rule of thumb is .004" gap for every inch of bore. So a 4" bore would be .016" gap. Unless it is blown or on nitrous, them it is about .006" per inch of bore.
Old 01-03-2008, 01:04 AM
Depends on what pistons you're using, also. Pistons with the top ring closer to the top (KB, for example) need more than the usual gap because the ring runs hotter and expands more from the heat.
Old 01-03-2008, 11:11 AM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
It is all up to the manufacturers specs and personal preference. I had a set of rings that recommended a .002 gap and surprisingly enough I only had to file one ring to achieve that number.
Need Correct Ring Gap Clearance newdad1 Engine 6 08-28-2007 03:50 PM
Piston ring end gap Oldphart Engine 2 01-06-2006 02:33 PM
ring gap with hyperuetectic pistons bullheimer Engine 5 06-04-2004 12:56 PM
KB pistons ring gap? nastynova Engine 4 03-21-2003 06:56 PM
Ring End Gap bpd411 Engine 3 02-26-2003 09:19 AM
