ring gap help. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2009, 07:31 AM
72fordlb's Avatar
BARN BURNING BIG BLOCK!
ring gap help.
So im about to build a engine for my truck now and im going to be running stock bore and im just going to hone it and put in some new rings and bearing and all the fun stuff. well my question is when i gap my rings how hard will it be and how much hp do you get from having the thighest ring gap as possible. Is there any down side to it.
Old 05-11-2009, 09:12 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You're running new rings in an old bore- if it were me, I'd throw a set of std. bore rings in it and call it good.
The amount of gain you'll see by going tight on the end gaps will be negated by the less-than-ideal seal you're gonna get running an old bore/pistons, IMO.
A rule of thumb (of many) says to multiply the bore by 0.004" for the top ring, 0.005 for the 2nd. ring, if you decide on a file-fit ring set.
Old 05-11-2009, 09:30 AM
83SILVRADO's Avatar
GROUND POUNDER
are you doin the 390 or 302?
Old 05-11-2009, 09:31 AM
72fordlb's Avatar
idk yet hopefully the 390
What happened to Piston Rings? Argess Engine 9 04-25-2009 03:17 PM
100 Shot Nitrous - Ring Gap HP52TA Engine 1 12-28-2008 03:36 PM
Ring gap question sgo70 Engine 9 09-12-2008 03:37 AM
KB pistons ring gap? nastynova Engine 4 03-21-2003 07:56 PM
Ring End Gap bpd411 Engine 3 02-26-2003 10:19 AM
