Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ring gap for hypereutectic pistons.
Old 11-17-2010, 06:01 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
Ring end gap is relevant to the heat load the rings will see.
If you are going to tow or supercharge or otherwise run it hard you can open up the ring end gap.
KB/UEM has specific ring end gap guidelines. If you follow them you won't go wrong.
