ring gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2005, 08:49 PM
ss396si's Avatar
ring gear
is their a way to measure the ring gear in the rearend? i have to measure the tooth side of the gear,correct?? im looking into buying a powertrax no- slip in my rearend. i want to know if its a 8.2 or 8.5
thanks
Old 04-30-2005, 09:42 PM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
What are the ID numbers on the axle housing?
Old 04-30-2005, 09:44 PM
ss396si's Avatar
its covered up in so much gunk i couldnt tell ya. it has chrome cover and 2 lugs underneath it
Old 05-01-2005, 06:13 AM
Lonestar's Avatar
What car is this in?
Old 05-01-2005, 07:46 PM
ss396si's Avatar
69 chevelle 10 bolt. everyones telling me an 8.2. axle code CA off the build sheet. it has to lugs underneath the cover that can be an 8.5.
Old 05-02-2005, 05:47 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Unless it has been previously swapped out, your car should have the 8.2.
I recommend scraping some of that gunk you described to us and getting some numbers, is there a possibility of a picture of the rear of the axle?
Old 05-02-2005, 06:26 PM
ss396si's Avatar
yes i have a picture
Old 05-02-2005, 11:49 PM
http://www.oldsmobility.com/10bolt-tech.htm has a decent ID guide.
Old 05-03-2005, 09:39 PM
ss396si's Avatar
according to that website its the 8.5. it has those lugs on the bottom of the housing. ill email you the pic
Old 05-09-2005, 03:44 PM
ss396si's Avatar
i got the casting number it is: 1235197
Old 05-11-2005, 08:44 AM
ss396si's Avatar
on the axle 1235197
Anti-gravity machine? NXS Hotrodders' Lounge 257 05-28-2006 09:48 PM
Ring gear spacer 1981monte Transmission - Rearend 2 10-14-2003 04:59 AM
flywheel ring gear somethin4nothin Engine 6 09-25-2003 08:36 AM
Rear ends...ring gear..? 67_Deuce Transmission - Rearend 1 01-23-2003 06:58 PM
