Ring gear bolts, lock washers or not? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2013, 11:04 AM
Overdriv's Avatar
I'm in the process of setting up a GM 12 bolt (car) gear set. I noticed the install kit came with lock washers for ring gear bolts along with some red ultra strength thread locker.
I don't remember using lock washers before, but maybe so, it's been a while since I did a rear end.
For a strictly street application, what's the best to use, regular lock washers like came in the kit, hardened flat washers, or no washers at all?
Of course Red thread locker regardless.
Old 12-02-2013, 11:37 AM
big gear head's Avatar
High Performance Rear Ends
All Chevy 12 bolt rear ends came from the factory with lock washers on the ring gear bolts. Some of the new rebuild kits have shorter bolts with a washer head on them. You can't use lock washers with those bolts because they are too short. If you are using a standard hex head bolt then use lock washers and the locktite.
The Following 2 Users Say Thank You to big gear head For This Useful Post:
AutoGear (12-02-2013), Crosley (12-02-2013)
12 Bolt Olds Rearend With 12 Bolts On Ring Gear BigBlockMan Transmission - Rearend 1 09-20-2009 10:39 PM
12 Bolt Olds Rearend With 12 Bolts On Ring Gear bmansr Transmission - Rearend 21 08-19-2008 02:52 PM
66 nova ignition lock ring.... sc2dave Electrical 2 04-24-2005 09:51 PM
New ring gear bolts? macx Transmission - Rearend 1 02-05-2005 10:27 AM
Correct Length, Ford Trac Loc Ring Gear Bolts? acr Transmission - Rearend 1 10-13-2004 06:17 AM
