Ring Gear numbers - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2003, 11:49 PM
Red face Ring Gear numbers
I have what i think is a rear end from an 1980 z28. The #'s on the ring gear are:
GM 3984828 3 40 3 80 . Can some one help me find a web site or more info on my ear end.
Old 08-31-2003, 11:23 PM
jdcoic's Avatar
The Chicken Car
These two websites have some pretty good info on identifying GM rearends.
http://www.oldsmobility.com/10bolt-tech.htm
http://www.nastyz28.com/camaro/zsusp.html#rearaxle
There should be a set of four #s, something like 15 41 stamped on the ring gear. This will tell you what ratio it is. Just divide the big number by the little one, and that is your ratio. The example above is 2.73
There is also the turn the driveshaft method. Count the number of times you have to turn the driveshaft to make the tire make one revolution, or ten times and divide by 10 (more accurate).
Old 09-03-2003, 07:17 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
If you can see the gears, simply count the teeth to find the ratio. Divide the number of teeth on the ring by the number on the pinion and you have the ratio. The extra numbers on hte ring are the specs used to install the gears originally. Everything will have to be measured again to reinstall them if they've been out or switched to another housing.
