ring gear numbers-9 inch ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2003, 08:34 PM
mike bryan's Avatar
Post ring gear numbers-9 inch ford
I've got a third member out of a 9 inch ford that I don't know what kind of gear ratio it has. There is no tag on the housing. I know that it is a 31 spline set up. The info stamped on the outer surface of the ring gear is: Ford USA D2AW 4210 AX2. The ring gear hub has stamped on it: C6AW 4205 B, and MCC 31. The third member housing has stamped on it : C7AW E 27. If anyone knows what gear ratio I have it would be helpful. The third member is in great shape and I would like to use it in my project. Thanks in advance. Mike
Old 04-20-2003, 11:24 PM
rfb92345's Avatar
Post
Why don't you just count the teeth? <img src="confused.gif" border="0">
Old 04-21-2003, 02:23 AM
deuce_454's Avatar
Post
count the teeth on the ring gear, and on the pinion. devide the two and you have the ratio, i could say somthing about rocket science but perhaps i should refrain... :-)
Old 04-21-2003, 02:20 PM
Post
[quote]Originally posted by deuce_454:
<strong>count the teeth on the ring gear, and on the pinion. devide the two and you have the ratio, i could say somthing about rocket science but perhaps i should refrain... :-)</strong><hr></blockquote>
Yes you should be " MORE SENSATIVE "
Some whiner was on the other day about his poor mistreatment.......
Some folks do not need to work on their cars. I am always amazed at how some folks can be so computer literate and smart but when it comes to cars.........
I do fairly well with Snapon, Mac and the like......but with Dell, Windows andd the like .......I am so lacking the needed skills.
