Ring gear spacer - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2003, 02:19 PM
1981monte's Avatar
Ring gear spacer
Can anyone tell me how thick a ring gear spacer is? I have a second gen. Diff. that will accecpt 3:08s down, I have a 3:73 set I would like to use with this posi unit. I just need to know how thick a ring gear spacer is so I can make sure that the ring gear is not centerd by only the bolts.
Thanks
Old 10-13-2003, 05:49 PM
BOBCRMAN@aol.com's Avatar
Ring gear spacers are different thickness' for each different type rear and ratio change, you mite be able to get the specs off Summit or Jegs on the Mr Gasket product lines.
Old 10-14-2003, 04:59 AM
302 Z28's Avatar
Also check Richmond Gear.
http://www.richmondgear.com/
Vince
