ring groove - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2008, 08:58 PM
powered by 1.21 gigawatts
ring groove
anyone the ring groove thickness of a ls7 454 piston?
Old 02-11-2008, 04:45 AM
Last journal entry: PICTURE TEST
ring groove
oil or compression???
keith
Old 02-11-2008, 06:14 AM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
3/16, 3/16, 5/64
Old 02-11-2008, 06:37 AM
rings
It's 5/64, 5/64, 3/16..The 5/64 are the compression and the 3/16 is the oil but...
I think there were some pistons with the 1/8" oil ring, they were all aftermarket pistons.
The only way to know for sure if you want to order the rings is measure them.
Keith
Old 02-11-2008, 11:01 AM
engineczar's Avatar
The ls7 is the 427 cu.in. engine in the ZO6 corvettes.
The rings are 1.2mm, 1.2mm, and 2.0mm oil ring.
BSE Racing Engines
Old 02-11-2008, 11:12 AM
Double_v23's Avatar
OOPS!!! Nice catch, that is what I meant.
Since he said LS and 454 I was assuming that he meant the ls6 454.
Need help,Pontiac 400 BEN24 Engine 4 09-05-2007 01:26 PM
Piston ring Question (For Nitrous) Ratoflic Engine 0 04-19-2006 04:04 PM
piston help, and or ring help blake carstensen Engine 2 12-08-2005 08:25 PM
snap ring problem antiquebob Transmission - Rearend 7 04-30-2005 04:24 PM
Piston Ring New Concepts brainsboy Engine 2 04-27-2004 03:55 PM
