Ring and Pinion - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2005, 04:50 PM
Ring and Pinion
I have a question(you guys will probably think boy is this guy stupid), on the ring gear for a 10 bolt(7.5 - 8.2 - or 8.5), are the dimensions the outside diameter of the ring gear? You won't believe me when I tell you that I called up the Summit Order department and he was not sure what the dimensions were based on.
Thanks in advance for your help, you guys have always come thru for me before. I looked thru the knowledge base but did not find my answer.
Old 01-17-2005, 05:45 PM
The ring gear diameter is dictated by the bolt circle that holds it to the carrier. 71/2 & 7 5/8 look identical and can be found in F bodies (and others) after about 1982. Seewww.drivetrainspecialists.com for some great ID info. Again, spline count will identify the differential also.
