Ring and Pinion Break in oil ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2013, 11:40 AM
Hey everyone,
I'm getting my new ring and pinion installed and was wondering what the proper break in oil is?
Its a GM 12 bolt with Posi, 3.73 gears installed. My plan was to run it with 80w-90 for the first 500 miles, then change it to synthetic 75w-90.
One other question, should I run the posi additive if its not making any sounds?
Thanks
Old 05-01-2013, 11:41 AM
big gear head's Avatar
High Performance Rear Ends
Sounds like a good plan. You can try it without the additive and put it in later if it needs it.
The Following 3 Users Say Thank You to big gear head For This Useful Post:
AutoGear (05-02-2013), Crosley (05-01-2013), xxllmm4 (05-01-2013)
Old 05-01-2013, 07:11 PM
What he said...
Old 05-01-2013, 09:12 PM
vinniekq2's Avatar
fyi,Ive never had a 12 bolt that didnt need the additive. Have fun with the new gears
Old 05-01-2013, 11:58 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
You don't need to start off with regular gear oil,
you can use synthetic from the get go, & if you use
either Amsoil or Lucas you wont need to use the additive
as limited slip friction modifiers are already in there.
I'd use 75w/140
Rich
Old 05-02-2013, 10:10 AM
S10xGN's Avatar
Gotta love a turbo!
I'm re-gearing my 9" with Yukon stuff from QuickPerformance. Their rep said never to use synthetic on new gears...
Russ
Old 05-02-2013, 11:32 AM
I know its not R&P related but when we build a gearbox from scratch, we recommend the initial break in be done with mineral based (ie non synthetic) 75w90 GL4
I imagine that it would be the same for the R&P sets
Old 05-02-2013, 08:03 PM
All the gear sets we do in my shop,all state to NOT use synthetic on break in,I always use a mineral based oil as recommended,even the "Cup" guys have told me they break theirs in with mineral based oil,been doing it that way for close to 30 yrs.With all these cheap crappy foreien gears,break in is critical
Are my ring and pinion still ok? zildjian4life218 Transmission - Rearend 41 09-22-2010 11:25 AM
I didnt break in my new ring gear & pinion jerellem Transmission - Rearend 29 04-30-2009 09:30 AM
Ring break-in? sexypizzaman Hotrodding Basics 15 03-18-2009 11:54 PM
8.5 ring and pinion oldsmo Transmission - Rearend 1 04-19-2006 09:32 AM
Ring and Pinion fred56 Transmission - Rearend 1 01-17-2005 04:45 PM
