ring and pinion install - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2005, 07:15 PM
red_rider52's Avatar
DriveItLikeItsSupostToBeD riven
Om here is my problem. I am installing used GM 10 bolt 3.42 ring and pinion in my rear end. I am trying to set up the wear pattern. The coast side looks perfect its right in the middle and takes up more than 3/4 of the tooth. Now the drive side is a different story i'm having a really hard time with it, On the tow side of the gear there is a pie shape and on the heal side it looks like the tooth is just barley touching. So it looks like its touching both sides and skipping the middle. My backlash at the moment is .011 of and inch, any help or ideas would be great thanks!
Old 04-07-2005, 08:19 PM
wildman926's Avatar
Never let them see you coming
HERE is Richmond's install instructions.
HERE is Yukon Gear's instructions.
Both have tooth wear patterns and remedies. Hope this helps.
Wildman
Old 04-07-2005, 08:59 PM
Thanks
The Yukon Gears one is great
It said when installing used gears the coast side is the most important and he pays very little attention to the drive side.
I have a good pattern on the coast side so should i put it all together and try it out? and just listen for noise and if there is none it should be good?
let me know what you think.
Old 04-08-2005, 09:32 AM
i just put it all together and tired it and i have a wine on acceleration, i'm not sure were to go now???
Old 04-08-2005, 09:11 PM
You could open er back up and recheck the pattern. If the pinion or ring moved, you get to do it all over I guess. If the ring and pinion are in spec. I'd run it.
Old 04-09-2005, 12:15 AM
i tried setting it up again i think i got it a little better and the wine isn't so bad. if you run it like that will the wine ever go away once it settles in or will it say???
Old 04-09-2005, 12:31 AM
I forgot it wine when there is a lite load, its most dominate around 2000 rpm
any other ideas or comments let me know.
Old 04-10-2005, 12:13 AM
New Member
I have just went through the same thing. I went ahead and took mine to the shop to make sure that it was done correct. I have heard a lot of people say that if you use the factory shims that it will get you really really close matter of fact the shop that I took mine to that is what they done and I have not had a single problem. But please dont take my word to heart!!!!!
I would think any noise would be really scarry? And by the way I have 3:73 gears and not so much as a peep out of them,
Old 04-10-2005, 07:56 PM
Any noise is a bad thing. How hot did it get when you took it for a drive?
Setting up used gears for the coast side just doesn't sound right to me (even though I have never set up gears before). I would think you would want to exactly match the existing wear pattern on the drive side and not worry much about the coast side.
Old 04-10-2005, 10:07 PM
wildman926's Avatar
RedRider,
PM M&M CUSTOM, he is very knowledgeable about differentials. He would be glad to help you out.
Old 04-10-2005, 10:34 PM
awesome thanks a lot guys
pinion/ ring gear exchange chevyman06 Transmission - Rearend 2 06-24-2004 06:47 AM
Which Ring & Pinion Kit? Ford 8.8" nightrain_rod Transmission - Rearend 0 12-03-2003 11:48 PM
9" ford ring & pinion install. kid Transmission - Rearend 4 05-07-2003 10:25 PM
On Average how much does a Ring and Pinion Rebuild cost? 2506CYL Transmission - Rearend 0 04-18-2003 05:20 PM
1965 Mustang 7 3/4" ring and pinion. dale634 Transmission - Rearend 6 12-15-2002 01:55 PM
