Hi,
I think you need to move the pinion deeper in toward the diff. carrier, add pinion shim. Good luck, rich PS I think you may need to move the ring gear a little farther from the pinion also, as it looks like to much tow contact Last edited by richard stewart 3rd; 09-18-2007 at 10:10 PM. Reason: norm, forgot stuff |
The pattern already appears to be oriented more towards the toe of the gear, if he adds shim and goes deeper towards the carrier, it will get worse.
It needs the pinion to be shallower to bring the pattern more towards center of gear and it should get deeper towards the root of the gear at the same time. |
The coast side looks OK though, the drive side looks like it is off by quite a bit to me.
Did you put resistance on the carrier when spinning it for the pattern? I usually press my hand firmly on the rear facing portion of the ring gear/carrier while turning the pinion yoke so I get good resistance and pattern read. |
Did you load the gear to get the pattern?
Be sure the bearing is pressed on good. I would take out .004 and see where it lands. Also be sure you clean all the compound off and start over. You have some dirt that is messing up your pattern. |
Hi,
try here for differential & gear pattern interpretation, http://www.drivetrain.com/ringpinioninstal.htm! rich PS I tried the address above & it won't connect so www.drivetrain.com then on the left in search box,type in, ring & pinion install Last edited by richard stewart 3rd; 09-19-2007 at 02:52 PM. Reason: address needs help |
Numbers generated by the lapping process cant account for the machining accuracy in your housing, which is why there are shims involved. The drive and coast patterns are close to the same radial point on the ring gear which means the pinion depth is very close. Your patterns is actually pretty good for a Richmond gear as they dont have a pattern like a stock gear, run hotter in a street car and are prone to noise. Gain some backlash and the drive and coast pattern will move to the heel.
| Problem setting up guts of ten bolt | rwruther | Transmission - Rearend | 18 | 08-30-2007 10:07 PM |
| Ring & Pinion Tooth Contact Pattern GM 10-Bolt | leejoy | Transmission - Rearend | 52 | 12-15-2006 06:26 PM |
| Ring & Pinion Setup - GM 10-Bolt Help | leejoy | Transmission - Rearend | 3 | 11-21-2006 07:02 PM |
| GM 8.5" 10-bolt Ring & Pinion Swap | leejoy | Transmission - Rearend | 21 | 08-29-2006 10:11 AM |
| 12 bolt Chevy truck pinion question | Gametech | Transmission - Rearend | 9 | 03-09-2004 05:02 PM |
