Most likely get razz`d for this but to be honest with the 10 bolt 8.5 ring and 30 spline setups... I found that either a .030 or .032 shim on the pinion is normaly puts you in the ball park... Depending on the gearset which you mentioned is Richmond (wise choice) then the setup backlash is .008-.010 Also remember the lapping of Richmond gears you may end up with some noise and may never get it out but just get to point where you can live it with and understand those Richmond gears are tough...
I know someone else can provide what your really wanting the step by step procedure but what I just gave you is a day to day set of spec`s that has yet to fail me... Of course check your pattern real close... One little tip if your unsure of things and want to be good to go just get another inside pinion bearing and use a die grinder with a flap sander (otherwise known as a chicken plucker) and take the press fit out of the inside of the bearing so it will just slid on the pinion shaft... This allows you to change shims as needed if your housing is a little off or machined different... Also use your old pinion nut till your ready for final assembly... |
Lee |
Thanks and here is another bit of info that might help ya...
http://www.drivetrainspecialists.com/setupspec.html |
| gm 10 bolt rearends | redchevyhotrodder2 | Transmission - Rearend | 4 | 07-19-2004 11:55 AM |
| Best place to find ring & pinion for 12 bolt...? | Bumpstick | Transmission - Rearend | 3 | 10-29-2003 11:50 PM |
| gm 10 bolt axle, bearings. | hepcat | Transmission - Rearend | 4 | 09-20-2003 08:36 AM |
| gm 10 bolt to ford 9 inch | junkyardracin | Transmission - Rearend | 4 | 08-31-2003 09:05 PM |
| 7.5" gm 10 bolt????? | Vancouver Grand Prix | Transmission - Rearend | 6 | 05-27-2003 03:49 PM |
