Ring & Pinion Swap - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-17-2013, 09:59 AM
malc's Avatar
Living At The Speed Of Life
Just ordered, Timkin #DRK320, itīs on itīs way courtesy of RockAuto.
  #17 (permalink)
Old 11-20-2013, 05:27 AM
malc's Avatar
Originally Posted by F-BIRD'88 View Post
80 MPH and 4000rpm does not equal a 2.73:1 gear ratio. Unless the transmission is stuck in 2nd gear.
It doesīnt, using the car today I ran 80mph and the rev count was just over 2000.
The law gave me the once over..........checking my 4" cowl for legality.
It doesīnt show up in the paperwork, but they decided it was legal being made of metal not fiberglass.
  #18 (permalink)
Old 11-20-2013, 01:16 PM
malc's Avatar
It is much more likely they hassled you because you were driving @ 80 MPH
than anything to do with a hood scoop.
They stopped me in town before I got to the freeway.
I need that big hicky to hide the illegal induction system under it.
  #19 (permalink)
Old 11-20-2013, 01:22 PM
It sounds like the Emission laws in Spain are as tough as places here in the United States. How does it work there?
BB
  #20 (permalink)
Old 11-20-2013, 01:38 PM
malc's Avatar
I only have to pass a tailpipe sniffer.
They never saw the car before I took all the emissions stuff of it.
Even the engine swap passed them by.
Back to rear ends, this is funneee.
  #21 (permalink)
Old 11-20-2013, 04:56 PM
big gear head's Avatar
High Performance Rear Ends
What an idiot!!! Someone take his tools away from him and delete that video. Someo people shouldn't be allowed to post videos.
  #22 (permalink)
Old 11-27-2013, 01:24 PM
malc's Avatar
I have my bearings.
3.23 ring and pinion is on itīs way.
I have a bearing puller.
I have a pinion yoke wrench.
New yoke too.
Outer axle bearings....on their way.
I have an inch pound torque wrench.
A bunch of stuff is held up at Summit, waiting on the Yukon shims.
And a slide hammer is ordered.
Itīll probably be snowing when Iīm ready to go.....
  #23 (permalink)
Old 11-28-2013, 08:31 PM
Ozz1967's Avatar
Air Force Guy
Originally Posted by malc View Post
I have the wonderful GM 7.5 inch carrier 2 rear.
I did say my first is lower and my overdrive is higher, but I got the trans so long ago I have no idea what those ratios are.
At the moment at 80mph Iīm turning 4000rpms.
I want the best of both worlds, acceleration and cruise economy..........
economy could, I suppose take the back seat....
Iīm planning a complete overhaul, ring/pinion, bearings and reusing my PowerTrax.
If I can get enough dough together, axles might be in there too.
This will be my first time "in the rear" so Iīve ordered a book and ībeen watching this,
My Summit cart floweth over.
I have an 84 Trans Am and run factory 215/65/15 tires (26" tall), factory 3.73 rear gears and a 700R4. I run 2600RPM at 70mph (115kph or so).
I like it because it's quick off the line and decent cruising. My car is carbed and I get 19 miles per gallon on the interstate, 14mph combined and around 12 if I stay in town.
  #24 (permalink)
Old 11-28-2013, 08:36 PM
Ozz1967's Avatar
Air Force Guy
Originally Posted by big gear head View Post
Yes, the Richmond kit is junk in my opinion. They have the junk differential shims, the same as come in the Ratech kits. Summit does not sell a good kit under any brand name. Timken bearings are the best, but the shims are what make the difference in a good kit and a junk kit. The Yukon kits from Randy's and the Dewco kits from Tom's have the best shims, along with Timken bearings. Jim sells the Yukon kits.
I bought a richmond kit to replace my gears when I broke some teeth off and they whined terribly...sounded like the pinion gear was bad out of the box. The shop took them out and reinstalled them three times before giving up. Apparently the ring and pinion gears need to be "matched"..they couldn't ever get them to set right and get rid of the whine. So, I ordered a set of motive gears and poof...problems solved. I only get a little howl around 45mph. Sold my Richmond gears to a guy who was going to use them in a track car.
  #25 (permalink)
Old 11-29-2013, 12:42 AM
malc's Avatar
I was going to order Richmond but decided to save a little cash and Iīm getting
Dana 3.23 gears @ $164 from RockAuto.
The Following User Says Thank You to malc For This Useful Post:
AutoGear (11-29-2013)
  #26 (permalink)
Old 12-07-2013, 01:13 PM
malc's Avatar
So far Iīve got the ring gear and carrier out, absolutely no preload on the pinion, itīll spin dead easy.
The gears are clean and undamaged.
I can assemble my new carrier and ring gear then install the bearings but Iīm still waiting on parts from Summit, no carrier shims until the 13th this month.
Iīve decided not to get the axle out, just too much hassle.
So Iīm on my back.....
  #27 (permalink)
Old 12-07-2013, 01:19 PM
I've been doing them on my back for 32 years. Keeps your abdominal muscles in shape. Just don't let anything fall on you. I had a Dana 60 differential fall out of a housing once and it almost got me in a very important place. Left a big chip in my concrete floor.
  #28 (permalink)
Old 12-07-2013, 01:36 PM
malc's Avatar
I undid the bearing cap bolts but left a few threads to catch the carrier as it came out.
Didīnt need to, it eased out nicely.
Iīm okay once Iīm under the car, just have to make sure all the tools I need are with me.
  #29 (permalink)
Old 12-07-2013, 02:15 PM
Yea, my 48 year old knees don't like getting up and down from the floor anymore. Probelm is now my 48 year old mind can't remember to get everything that I need before I get under the car. I always had plans to get a lift, but it never happened.
  #30 (permalink)
Old 12-08-2013, 02:23 AM
malc's Avatar
And I thought I have problems with memory at 62......err....63 !!
I already have a aluminum diff cover with bearing supports on it, Iīm also going to install studs for the bearing caps and ditching the crush sleeve for spacer/shims.
Upgrades recommended in a book I bought by Randy Lyman of Randyīs Ring & Pinion.
8.2 69 chevelle ring & pinion swap 69chevman Transmission - Rearend 3 03-19-2009 02:29 PM
3.42 to 4.10 Ring and Pinion Swap Regal Beagle Transmission - Rearend 5 01-27-2009 09:27 PM
How hard to swap out ring and pinion gears? murrsue Transmission - Rearend 4 04-02-2007 07:59 PM
GM 8.5" 10-bolt Ring & Pinion Swap leejoy Transmission - Rearend 21 08-29-2006 11:11 AM
Ring and pinion swap NovaSS350 Transmission - Rearend 13 10-06-2004 11:05 AM
