Ring & Pinion Swap - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 01-12-2014, 11:39 PM
malc's Avatar
Living At The Speed Of Life
Originally Posted by big gear head View Post
Chilton is wrong, it's 70. 65 will work too. Just be sure to use the red Locktite on the bolts.
Waite until you start compressing the crush spacer. It takes around 300 foot pounds for that.
Iīm going to use a pinion bearing spacer kit.
Iīve also got a pretty big torque wrench thatīll give me leverage.
Off to the tire dealer, he might have a left handed torque wrench
for the ring gear bolts.
Iīve got red Locktite too.
  #62 (permalink)
Old 01-13-2014, 09:12 AM
malc's Avatar
He had the tool and now the ring gear bolts are Loctited and tight.
I have the pinion in with checking bearings tightened just enough to take up slack.
The diff is in and loosely shimmed, this is my first pass with the marking compound.
Couldīnt find any match in the two books I have but Iīm guessing the ring gear has to move away from the pinion a tad.
  #63 (permalink)
Old 01-13-2014, 09:46 AM
big gear head's Avatar
High Performance Rear Ends
Pinion is way too deep. Take about .010 out of the pinion shim and try again. Be sure that you have the bearing preload and backlash set correctly each time you check it. If the pinion bearing preload is not set the same each time then the pinion depth will not be accurate.
The Following User Says Thank You to big gear head For This Useful Post:
malc (01-13-2014)
  #64 (permalink)
Old 01-13-2014, 09:58 AM
malc's Avatar
There was one original pinion shim, which I used as a starting point per your advise.
Itīs pretty thin, didīnt measure it, will do so tomorrow.
  #65 (permalink)
Old 01-13-2014, 10:16 AM
It should be around .030. Before you change the shim be sure that you have the bearing preload set to about 20 inch pounds. If you don't then set the preload and do another pattern check with this shim. Also be sure that the bearing race and bearing are completely seated. I don't know how many times someone has run into problems, only to find out that there was a burr or something keeping the bearing race from seating completely.
  #66 (permalink)
Old 01-14-2014, 05:51 AM
malc's Avatar
With pinion preload set to 20inch pounds, I finally got to this, after several shim changes on the pinion.
This pretty much matches an acceptable example in my Diff. book.
Backlash is 0.040.
  #67 (permalink)
Old 01-14-2014, 06:03 AM
You say that backlash is .040. Is that correct or did you mix up the numbers? .040 backlash is WAY too much.
The pattern doesn't look too bad, but it's too far toward the heel of the tooth. The depth looks about right. What does the coast side look like? You must check both, drive and coast patterns.
malc (01-14-2014)
  #68 (permalink)
Old 01-15-2014, 09:13 AM
malc's Avatar
0.040 was a typo....shoulda been 0.0040.
To say I verged on madness today would be..........about right.
I think Iīve run out of shim combinations totally....
Finally I got these patterns on drive and coast with 0.005 backlash.
Correct backlash is 0.005-0.009.
Drive
Coast
This is from my book,
 Differentials by Jim Allen & Randy Lyman. Differentials by Jim Allen & Randy Lyman.
  #69 (permalink)
Old 01-15-2014, 02:23 PM
Are you turning it with the pinion or with an axle? If you are turning it with the pinion then stop and use an axle to turn it. The pattern will be more clear and easier to read. The coast pattern doesn't look like it wiped away enoug compound. Stick an axle in it and turn it about 6 times in both directions and see if the pattern becomes easier to read.
You may be close, but I don't want to tell you if it is or not with the pattern looking like that.
  #70 (permalink)
Old 01-15-2014, 11:50 PM
malc's Avatar
Iīm turning it with the pinion while putting drag on the ring gear.
To use an axle Iīll have to pretty much rebuild the whole thing.
I find that once the pinion has compound on it it tends to transfer back to the ring gear.
  #71 (permalink)
Old 01-16-2014, 06:11 AM
I don't understand why you have to pretty much rebuild the whole thing to use an axle. I've done several hundred of them that way. When you have the differential installed and the backlash is set just stick and axle in it and turn it.
  #72 (permalink)
Old 01-16-2014, 10:37 AM
malc's Avatar
I didīnt want to install the Powertrax just yet, nor the outer bearings.
Anyhows hereīs another swipe at it.
Quite honestly I donīt think Iīm going to better this.
  #73 (permalink)
Old 01-16-2014, 12:11 PM
It doesn't look bad to me. I'm guessing that you have gone thinner and thicker with the pinion shim and this was the best.
I understand why you didn't want to assemble the Power Trax. I had forgot that you were using that.
  #74 (permalink)
Old 01-16-2014, 01:47 PM
malc's Avatar
I just ran out of combinations on the pinion shims, the one I used was the last chance shim.
I got to the tire dealer just before he closed and pressed the bearing onto the pinion.
  #75 (permalink)
Old 01-19-2014, 05:20 AM
malc's Avatar
Today I took the bearing off and added a thin shim.
Found out I can use my bearing removal tool to install too.
This is where Iīm at, 0.005 backlash, 25inchpounds on the pinion.
8.2 69 chevelle ring & pinion swap 69chevman Transmission - Rearend 3 03-19-2009 01:29 PM
3.42 to 4.10 Ring and Pinion Swap Regal Beagle Transmission - Rearend 5 01-27-2009 08:27 PM
How hard to swap out ring and pinion gears? murrsue Transmission - Rearend 4 04-02-2007 06:59 PM
GM 8.5" 10-bolt Ring & Pinion Swap leejoy Transmission - Rearend 21 08-29-2006 10:11 AM
Ring and pinion swap NovaSS350 Transmission - Rearend 13 10-06-2004 10:05 AM
