Ring & Pinion Swap - Page 7 - Hot Rod Forum : Hotrodders Bulletin Board
  #91 (permalink)
Old 01-22-2014, 01:18 PM
malc's Avatar
Living At The Speed Of Life
The difference in these carriers appears to be on the ring flange side,
the 2 carrier is machined deeper.
The 2 carrier has one big window and a small one, the 3 carrier has two big windows,
the 2 looks much stronger.
3 carrier.
2 carrier.
  #92 (permalink)
Old 01-22-2014, 02:13 PM
big gear head's Avatar
High Performance Rear Ends
The 2 series is probably a 7.6 differential and the 3 series is probably a 7.5 differential. If you were here I could fix you up easily. I've got a pile of this stuff from jobs I've done over the years. I've hauled off many truck loads of these things, and I've still got more than I could use in many more years.
  #93 (permalink)
Old 01-22-2014, 11:31 PM
malc's Avatar
Thou tauntest me somewhat......
  #94 (permalink)
Old 01-23-2014, 08:40 AM
malc's Avatar
Removed the ring gear from my 2 carrier today.
I say removed, the bolts were not tight and it fell off...
Itīs cleaned up, the bearings are on, just waiting on the new ring and pinion..............start over.
  #95 (permalink)
Old 01-26-2014, 10:32 AM
malc's Avatar
Had a great time on my back today getting rear end gear oil off the underbody, boy was that crud thick.
Had to use a scraper first then degreaser.
  #96 (permalink)
Old 01-28-2014, 02:25 PM
malc's Avatar
The new gearset arrived this morning.
The ring is on.
The pinion is in.....provisionally.
Let the fun begin again.
  #97 (permalink)
Old 01-29-2014, 08:16 AM
Huzzah!!!
  #98 (permalink)
Old 01-29-2014, 09:05 AM
malc's Avatar
Got this far, cold stopped play....
  #99 (permalink)
Old 02-03-2014, 02:15 PM
malc's Avatar
This is where Iīm at today, installed new stainless brakeline.
  #100 (permalink)
Old 04-04-2014, 05:17 AM
malc's Avatar
Axle revisited......
I had it all together and there was a whine from it, I thought, maybe too much preload and I wasīnt that confident using the crush sleeve elininator spacer.
So recently I did it over, pinion preload 20inlbs.
Tucked it back under the car and it still whines.
Chiltern says 15 - 30 inlbs on the pinion (new bearings) but where must it be not to whine ?
Should I now tighten the pinion nut a little at a time until it stops whining or was 20 inlbs already too much ?
  #101 (permalink)
Old 04-04-2014, 05:58 AM
20 inch pounds is about perfect. The noise is not coming from the pinion bearings, it's coming from the gears.
I just looked at your contact pattern and it looks like you could use about .002 more on the pinion shim. Maybe that would help. Some gears are going to make a little noise no matter how well they are set up.
  #102 (permalink)
Old 04-04-2014, 09:22 AM
malc's Avatar
Thanks....
Doing the pinion shim is too much for me to do at the moment.
Iīve had the axle out of the car twice now.
As long as itīs not going to destroy itself,
I can stand the whine for a while.
  #103 (permalink)
Old 04-04-2014, 01:22 PM
ericnova72's Avatar
More for Less Racer
If you drive it with it the way it is, the gears will wear in that way("Take a set") and you will have that whine in the gearset forever, there will be no correcting it.
The Following User Says Thank You to ericnova72 For This Useful Post:
malc (04-04-2014)
  #104 (permalink)
Old 04-04-2014, 02:42 PM
malc's Avatar
Itīs not a loud whine.....irritating is what it is.
Anyhow Iīve just ordered up a couple of crush sleeves, pinion seals and a shim kit.
No parts for my back though....
  #105 (permalink)
Old 04-04-2014, 04:19 PM
Just remember, some gears will make a little noise. It's in the way they are cut. If the operator doesn't get the machine set up just right the gears will make some noise, no matter how well you set them up.
The Following User Says Thank You to big gear head For This Useful Post:
Crosley (05-01-2014)
8.2 69 chevelle ring & pinion swap 69chevman Transmission - Rearend 3 03-19-2009 01:29 PM
3.42 to 4.10 Ring and Pinion Swap Regal Beagle Transmission - Rearend 5 01-27-2009 08:27 PM
How hard to swap out ring and pinion gears? murrsue Transmission - Rearend 4 04-02-2007 06:59 PM
GM 8.5" 10-bolt Ring & Pinion Swap leejoy Transmission - Rearend 21 08-29-2006 10:11 AM
Ring and pinion swap NovaSS350 Transmission - Rearend 13 10-06-2004 10:05 AM
