Ring & Pinion Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2013, 11:48 PM
malc's Avatar
Living At The Speed Of Life
Ring & Pinion Swap
Itīs time to address the clunking in my rear axle, itīs now 27 years old and has never been touched.
The original ring and pinion ratio is 2.73:1, I was looking to 3.42s to get some zippy acceleration, but would more conservative 3.08:1 serve me better ?
Bearing in mind the B/M 700R4 I have has a lower first and higher overdrive,
but I cannot give any info on the exact ratios.
Old 11-15-2013, 06:30 AM
big gear head's Avatar
High Performance Rear Ends
The 700 has a 3.06 first gear and overdrive is around .70. What are you working on and what rear end does it have in it? You may have to change more than just the gears, depending in the rear end.
Old 11-15-2013, 07:28 AM
Malc is working on his 3rd Gen F-body, he's in Spain as well.
I do not know if he has the typical rear axle in his car or the oddball Aussie built 9 bolt
Old 11-15-2013, 08:49 AM
malc's Avatar
I have the wonderful GM 7.5 inch carrier 2 rear.
I did say my first is lower and my overdrive is higher, but I got the trans so long ago I have no idea what those ratios are.
At the moment at 80mph Iīm turning 4000rpms.
I want the best of both worlds, acceleration and cruise economy..........
economy could, I suppose take the back seat....
Iīm planning a complete overhaul, ring/pinion, bearings and reusing my PowerTrax.
If I can get enough dough together, axles might be in there too.
This will be my first time "in the rear" so Iīve ordered a book and ībeen watching this,
My Summit cart floweth over.
Old 11-15-2013, 09:02 AM
You can get special thick 3.42, 3.73 and 4.10 gears for the 7.5 with the 2 series differential. If you are planning an upgrade from 26 to 28 spline axles then you will need a 28 spline differential and a new Power Trax to go with it.
If I get time later I will try to watch that video, but you have to be careful about what you watch. There are MANY youtube videos on building rear ends that are COMPLETELY WRONG.
I would recommend a 3.42 or 3.73 at the most. The 3.06 first gear in the 700R4 will make a 3.42 seem like a 4.10 in first and a 2.41 in overdrive as compared to a TH350. A 3.73 would be like a 4.56 in first and a 2.56 in overdrive.
If you get a vibration at highway speeds you will have to get a better dirve shaft. A stock drive shaft is not made to handle the higher RPMs that you will see after this gear swap. This is a very comon problem when changing gears.
Contact Jim at www.jdrace.com and see if he will ship parts to you. The installation kits and some of the other rear end parts that Summit and Jeg's sell are junk. I do not recommend buying rear end parts from them.
The Following User Says Thank You to big gear head For This Useful Post:
41 Buick custom (11-15-2013)
Old 11-15-2013, 09:11 AM
[QUOTE=big gear head;1913394]You can get special thick 3.42, 3.73 and 4.10 gears for the 7.5 with the 2 series differential. If you are planning an upgrade from 26 to 28 spline axles then you will need a 28 spline differential and a new Power Trax to go with it.
If I get time later I will try to watch that video, but you have to be careful about what you watch. There are MANY you tube videos on building rear ends that are COMPLETELY WRONG.
I for one would appreciate that. I'm thinking of changing out the gears in my 2000 E350.
BB
Old 11-15-2013, 09:21 AM
malc's Avatar
The guy in the video, John Kelly at Weber State University seems pretty legit.
Old 11-15-2013, 01:25 PM
OEM 3.23 to 4.10 gears will not fit the 2 series differential. You will need a 3 series to use them.
Crosley (11-16-2013)
Old 11-16-2013, 04:15 AM
malc's Avatar
My rear gears are 2.73, series 2 carrier.
From what Iīve read above Iīm more than likely going for
Richmond Gear Ring and Pinion Sets 4900051
using their installation kit 8310441.
I wonīt be updating to 28 spline axles either, itīs going to be expensive enough as it is, remember I have shipping and import to pay.
The torque converter in my car is a B&M Holeshot Torque Converter 70415.
Old 11-16-2013, 06:58 AM
Those gears will work fine, but that installation kit is junk. Like I said before, all of the kits that Summit and Jeg's sell are junk. Tom's Differentials and Randy's Ring & Pinion have the best installation kits. Jim at www.jdrace sells Randy's kits and he might ship to you. He also sells their gears which are also good.
Here is something that you might want to look at. http://www.thirdgen.org/techboard/tr...axle-gear.html
malc (11-16-2013)
Old 11-16-2013, 08:06 AM
I watched the video. Certainly not the best that I've seen. One thing that I do NOT agree with, about 4 minutes into this he says that pinion bearing preload must be set before anything else can be done. Setting the pinion bearing preload with the crush spacer or even the solid spacer is a complete waste of time until you have the pinion depth set. Yes, you must set the bearing preload on each trial assembly, but not with the spacer installed. That is done at the final assembly, after the pinion depth and backlash have been set to get the correct contact pattern.
Also, checking the bearing preload with the ring gear and differential installed is a complete waste of time. If you measure the preload at 30 inch pounds with a 2.73 gear and you set up a 4.10 gear with the very same amount of pressure on the bearings then the preload is going to measure much less because of the leverage difference between the 2.73 and 4.10 gears.
There are a few other things that I don't completely agree with, but I'll let them go for now. Just be sure to get your pinion depth set correctly before you install the crush spacer and pinion seal.
malc (11-16-2013)
Old 11-16-2013, 10:51 AM
malc's Avatar
Here is something that you might want to look at. 10 bolt axle gear install by the numbers (pic heavy) - Third Generation F-Body Message Boards
The installation kit I linked is a Richmond, Summit sells them but are they junk ?
From thirdgen.org;
"Move on to a better install kit from Yukon, Precision Gear, Moser, or Richmond Gear. You will get more complete kits and usually better bearings."
For pinion depth setting I thought of using this, Ratech Pinion Depth Setting Tools 10003.
I did get the need to set the depth first, otherwise your going to screw up
a load of crush sleeves.
The thirdgen.org link is good Iīve book marked it for later.
Iīll have access to a press and have ordered up an inchpound beam torque wrench.
Iīm off to explore jdrace.com.
Old 11-16-2013, 10:55 AM
malc's Avatar
jdrace.com says....
Ring and Pinion Gears
There are no products.
Rebuild Kits
Rebuild Kits
Old 11-16-2013, 11:20 AM
I like these guys and I know they ship overseas.
Welcome To Lane Automotive - supplier of racing & high performance parts and accessories
Any kit that has Koyo or Timkin bearings is OK, you can get a complete kit from Timkin #DRK320 or in National brand which is also Timkin bearings in #RA320.
Old 11-16-2013, 02:18 PM
Yes, the Richmond kit is junk in my opinion. They have the junk differential shims, the same as come in the Ratech kits. Summit does not sell a good kit under any brand name. Timken bearings are the best, but the shims are what make the difference in a good kit and a junk kit. The Yukon kits from Randy's and the Dewco kits from Tom's have the best shims, along with Timken bearings. Jim sells the Yukon kits.
8.2 69 chevelle ring & pinion swap 69chevman Transmission - Rearend 3 03-19-2009 01:29 PM
3.42 to 4.10 Ring and Pinion Swap Regal Beagle Transmission - Rearend 5 01-27-2009 08:27 PM
How hard to swap out ring and pinion gears? murrsue Transmission - Rearend 4 04-02-2007 06:59 PM
GM 8.5" 10-bolt Ring & Pinion Swap leejoy Transmission - Rearend 21 08-29-2006 10:11 AM
Ring and pinion swap NovaSS350 Transmission - Rearend 13 10-06-2004 10:05 AM
