ring reuse - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2012, 03:51 PM
ring reuse
Recently had a cam lobe failure on a flat tappet. I tore the engine down to setup my new valve train, and I disassembled the short block to clean the components and replace the bearings and pump. My engine had under 1000 miles, and now i have a couple people telling me i cannot reuse my rings since i removed them from the bores.. They claim the rings have hardened with use and may crack.. They are total seal TS1'S and I really dont want to replace them with such little use. They had under 5% leakage(cold), Its very close to christmas, and i just spent a bunch on a HYD roller setup. What do you guys think?
Old 12-01-2012, 04:48 PM
hcompton's Avatar
Old & Furious
Do you have the pistons marked with the rings still installed. They need to go back in tje same cylinder and normally you dont put them back in. But at low miles ppl have done it. It may not seal up and smoke if you do not replace them. But if you do and it does not smok after a few miles then your fine. Just taking a chance at needing to replace them early.
What type of rings are they?
Old 12-01-2012, 04:53 PM
they are total seal brand with gapless 2nd. TS1. Rings are still on the pistons & the rods are marked.
Old 12-01-2012, 05:18 PM
hcompton's Avatar
Old & Furious
The iron rings have surly seated in by now. You got good chance of them working but might not be worth the issue if it needs to last. I would just get a new set and be done with it.
Old 12-01-2012, 06:08 PM
BOBCRMAN@aol.com's Avatar
If you replace pistons/rings in the same bore they came from. The rings will be alright to re-use. They will seal up and give no problems. I've seen it done dozens of times..
Old 12-01-2012, 06:41 PM
Wiki Edits: 27
reuse?
years ago when my brother was doing a lot of racing he would pull the engine apart every couple months clean up everything remove any carbon, polish the valves. He would just do a glaze breaker lightly on the cylinder walls and reuse the rings, back to the same bores.
Old 12-01-2012, 07:20 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
Got mixed feelings about this one.I hear ya about the leakdown test being cold 5%.Btw-thumbs up for doing the leaddown.Yet they where exposed to the fragments of the failed lifters too. Got me wondering what a leakdown would be hot. I guess you could get lucky.Maybe you wait until after the holiday's costs and then get back to it with a fresh set of rings.It's a $100.00 save bet.
Old 12-01-2012, 07:54 PM
vinniekq2's Avatar
I ve reused rings a few times,not on an engine that took damage.how much is a set of rings and your time worth? try it?
Old 12-01-2012, 11:57 PM
Thanks for the opinions guys. Think I am going to chance it. The TS1's are $250 dollars these days, these are already gapped and i am just not ready to give up on them yet. I knew from the start there was some risk of them not sealing again and i am ok with that. The local racers i spoke with just made it seem like there was little to no chance of success so I felt the need to seek a few more opinions. The debris was only from one lobe and it was caught early. Basically i just pulled it apart to clean the block so that nothing gets in the new lifters (went to hydraulic rollers).. my bearings were actually pretty good, and i might even be tempted to use them again if i hadnt already bought the parts and have it on the stand.. I will say I am now a firm believer of using magnets on the walls of the pan sump, eliminating the bypass in the adapter, and using 1794 filters. My oil drained out fairly clean, and the magnets and filter were definately working.
Ok to reuse AN sleeves? staleg Suspension - Brakes - Steering 4 07-14-2012 12:25 PM
reuse lifters? awoodman Engine 22 09-05-2007 08:58 PM
reuse lifters? Blackhauk90 Engine 26 08-24-2007 07:43 PM
reuse cam? 84KYSS Engine 1 05-16-2006 05:43 AM
timing chain reuse? fireforsin Engine 10 09-17-2004 08:50 AM
