Ring Size ? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-05-2011, 01:17 PM
Checked the piston clearance is .009
  #17 (permalink)
Old 09-05-2011, 01:24 PM
BOBCRMAN@aol.com's Avatar
A .030" piston will require a .030" ring and a .030" hole. There is no way you can run a .030 piston in a .050" hole.
The required piston to wall clearance is built into the skirt.
I run into similar situations with old retired guys that decide to repair small engines.. Repeatedly having to tell them that you have to run the correct oversize piston in an overbored cylinder. NOT just put oversize rings on a standard piston..They get a bit noisy that way! Plus they smoke profusely...
  #18 (permalink)
Old 09-05-2011, 01:27 PM
Most clearance you can run on that type piston is .003" might be noisy even at that.. .040" oversize is available.. But the dimensions you are getting don't add up..
  #19 (permalink)
Old 09-05-2011, 02:21 PM
.009 is alot of clearance but will work OK as long as you understand that ring and piston life will be decreased.
  #20 (permalink)
Old 09-05-2011, 02:31 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I used a telescopic bore gauge and quality digital micrometer and they were all around 4.050 average...
Well the piston mics out @ 4.030
You sure this engine wasn't built as a demo derby mill? But if the p to w is 0.009" and the pistons are 0.030", the bore can't measure 4.050".
If you keep this block, have it checked for bore diameter by a shop and sonic'ed and if it's OK to take out to 0.040" or 0.060" over, do that. There's no way you will get a satisfactory rebuild out of it the way it sits, IMO.
So could I use .20 rings and check ring end gap clearance since the bores just under 4.050 or would this be an issue
I think you mean 0.020" not ".20", but either way, no- this will not work.
  #21 (permalink)
Old 09-05-2011, 04:13 PM
I rechecked everything the piston diameter @ the skirt is 4.0560
The bores are 4.0550
  #22 (permalink)
Old 09-05-2011, 04:50 PM
Again, the bore is 4.055" and the piston is 4.056 that won't work.
Measure the skirt directly across from the pin bore.It has to read at least .001 less than the bore.
Try this. get an inexpensive set of feeler guages. use the .001 leaf and place it alongside the piston with the end of the leaf at the pin area of the skirt. then place this in the hole. it should have light drag but pass up and down. Repeat this with the next size till the assembly locks up. next smaller is your clearance.
Probably a .060 bore..
  #23 (permalink)
Old 09-05-2011, 05:13 PM
Sorry Bob, I entered that backwards bore is 4.0560 piston is 4.0550
What size ring gear in 84 Z28 Greg T Transmission - Rearend 3 05-10-2009 02:59 PM
Piston type or ring size? biscuitville Engine 5 12-19-2008 11:37 AM
pisston ring size tar-heel-smoker Hotrodders Site Suggestions and Help 3 03-25-2007 10:33 PM
350 ring size on 60 oveR? Trav Engine 2 01-17-2004 06:03 PM
ring gap size 66hedsup Engine 1 04-26-2003 05:52 PM
