Ripples on pleated seat panel - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2010, 08:45 PM
Elleka's Avatar
Last journal entry: Old interior
Is it normal for my pleated seat panels (top stitched to 1/2" sewfoam) to have ripples? Will they disappear when I stretch the seat cover onto the seat? I don't want to start my other panels if I'm doing something wrong. The fabric is a faux suede, not Ultraleather, with a woven white backing.
Old 05-31-2010, 07:44 AM
DanTwoLakes's Avatar
Wiki Edits: 22
All fabrics act differently, but those wrinkles should come out when the seat cover goes on. You may want to make the panels slightly smaller front to back, say 1/4" to 1/2".
What did you glue the fabric on with?
Old 05-31-2010, 09:40 AM
Elleka's Avatar
Good morning Dan. Thanks for the response. I used "Dan Tack Foam and Fabric" (# 2012) Spray Adhesive in an aerosol can.
Old 05-31-2010, 10:06 AM
Wiki Edits: 22
Then you should be just fine. If the wrinkles don't come out when you put on the seat cover, they will come out when the seat gets warmed by the sun.
Old 05-31-2010, 03:23 PM
Elleka's Avatar
Thanks again Dan.
Old 06-14-2010, 01:01 AM
I used some garbage glue that did the same thing
Need Some Fabrication Ideas - Solutions for a Retractable Panel icsmannn Body - Exterior 3 05-21-2010 08:14 PM
Welding a panel in place Quarter Flash Body - Exterior 6 03-22-2007 02:56 AM
Power Seat Wiring Info Needed- Mid 70's Chevrolet/Chevelle LongTom Electrical 1 02-06-2007 01:36 PM
Help! What To Do With These GIGANTIC Dents!? mistermuscles Body - Exterior 14 09-16-2005 05:24 AM
Can not figure out how to remove rear seat. HotRodMan Interior 7 04-26-2004 07:27 PM
