is it the rite combination - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2010, 07:06 PM
mtg mtg is offline
I have a chevy 400 bore.040 flat top piston 555 duration solid lift cam roller rocker,750 holley vaccum sec,2800 to3200 stall 350 tranny 456 gear msd box 6al and distributor and my car don't have the take off where did I go wrong
Old 08-19-2010, 08:17 PM
ericnova72's Avatar
More for Less Racer
Be clear and give a little more detail about what you have, I couldn't make heads or tails of some of that run-on sentence.
There are .555" lift cams, but there are no 555° duration cams, list all your cam specs- duration, lift, lobe seperation, intake lobe centerline.
List the distributor timing specs you are currently using.
Tell us about your entire fuel system.
"My car don't have the take-off" is not very specific. Be more descriptive of the problem you are having.
454 Transmission/Differential Combination grandfisher Transmission - Rearend 2 06-08-2009 08:03 PM
The D.O.T. gonna gitcha. coldknock Hotrodders' Lounge 32 10-31-2007 06:33 AM
Combination Valve advice required old pop General Rodding Tech 5 08-31-2006 05:16 PM
Tripped Combination Valve Sweet-34 Suspension - Brakes - Steering 5 03-22-2005 04:57 AM
Combination valve for disk/drum setup TurboStude Suspension - Brakes - Steering 1 04-01-2002 06:39 AM
