Originally Posted by Not A T 25
1. Retighten bowl screws & power valve;
Bowl screws are tight. I did not check the tightness of the power valve with a wrench. It seemed to be tight otherwise. Since there is no power valve in the rear bowl and it also loses gas after sitting, this does not seem to be a possible area of concern except for the front bowl. I will check this out.
2. replace bowl, metering block, & power valve gaskets,
I have not changed any of the gaskets as they seemed OK. No gas is leaking to the outside areas of the carb. I do have gaskets on order at this time.
3. clean the air bleeds
I saw nothing internally that would cause any blockage or stop the flow of gas or air. The carb actually ran well for the "out of the box" factory settings. Very responsive. It is a little rich and I have not adjusted the air/fuel screws yet. The only adjustment I have done to date is the idle speed has been set to 700 RPM with the trans in Drive, choke fully open, engine at operating temps, and the air cleaner installed.
Thanks
Not A T 25 for your reply.
